Finding Angle of String with Two Charged Balls
  • Thread starter Thread starter Quinn Pochekailo
    Angle String
To find the angle θ that the string makes with the vertical for a charged ball suspended from a ceiling, the forces acting on the ball must be analyzed. The x-component of the force due to the attraction between the two charged balls is calculated using Coulomb's law, resulting in a force of 5.6e-14 N. The y-component is determined by the weight of the ball, calculated as F=mg, yielding a force of 0.5 N. To find the angle, one can use the ratio of the x and y components, applying trigonometric functions. Alternatively, small angle approximations can simplify the calculations.
Quinn Pochekailo
http://loncapa.vcu.edu/res/vcu/phys202/zzImages/Ch25_TB.jpg
A charged ball with charge Q1 = 0.1 μC and mass 0.05 kg is suspended from a ceiling with a thin massless string as shown in the figure. The second charged ball has a net charge Q2 = -0.5 μC and it is located d = 0.3 m away from the suspended ball. What is the angle θ that the string makes with the vertical (dahsed vertical line) as shown in the figure? Provide your answer in degrees. (Note: The dashed horizontal line is not a string or rod, it only designates the distance d between the two spheres)
F=(K*Q1*Q2)/ (d^2)
I converted the charges to C first, getting 1e-7 and -.5e-7. Because the charges are attracting, I found that the force is equal to 5.6e-14, which would be my force in the x component. The y force component would be equal to F=mg, which is (.05 * 10). How would I go about finding the angle with these 2 values?
You have a force whose x component is known and whose y component is known, right?
There is an easy way to do this and a hard way. The hard way is to compute the magnitude of the tension force first. You know its x and y components, so you should be able to find its magnitude. Then write down an equation for the x component of the tension force in terms of its angle and magnitude.
The easy way is to think about the ratio of the two components. There is a trig function that is equal to that ratio...
Edit: Or, there is a slightly easier way, if you are comfortable with small angle approximations.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
  • · Replies 23 ·
9K
