Finding the Angle of Trajectory
  • Thread starter Thread starter Lamebert
    Angle Trajectory
The discussion revolves around determining the launch angle θ of a projectile based on its speed at maximum height and half its maximum height. The key relationship established is that the speed at maximum height is half the speed at half maximum height. Participants suggest using standard constant acceleration equations to relate velocity and height, specifically vf² = vi² + 2ad. The challenge lies in connecting these equations to find the angle θ, as the variables involved complicate the solution. The conversation emphasizes the need to clarify how velocity and height interact within the equations to solve for the angle.
Lamebert
A projectile is launched from the earth’s surface at initial speed vi at angle θ0 with the
horizontal. When the projectile is at its maximum height h, it has half the speed it had
when it was at half its maximum height h/2
At what angle was the projectile launched?
I know that the velocity vector at the highest point is vicosθ, and I know that the maximum height of the parabola is (visinθ)2 / 2g. At this point, I don't really know where to go. I'm not sure how to relate height and velocity together with what I know. I was doing this earlier and I tried to go further, but I just ended up with a lot of variable/trig function couples that don't make sense. I could take a picture of all the work I've done, but you wouldn't be able to follow it. I barely know what I tried.
You don't really have to answer it for me, just what should the next step be?
Hi Lamebert! Welcome to PF! :smile:
You need to translate …
… into one of the standard constant acceleration equations :wink:
Thanks for the welcome, and can you go a little further? I already knew I was going to need those equations, I just don't know how they fit together, how velocity and height at each point should relate inside of the equations.
well, you know the velocity at two different points, and the distance between them (and the acceleration),
sooo the equation to use is … ? :smile:
vf2 = vi2 + 2ad
The problem is finding the angle theta, though. I know that vicosθ = v, right? But if I set that equal to what I solved for from the above equation, that is, v = √(gh /3), i end up with two variables again, which doesn't really help me.
