Finding angular Momentum from a force
The discussion revolves around calculating angular momentum and torque from a given force acting on an electron. It is clarified that the torque is zero for a central force, as the force and position vector are aligned, leading to no angular acceleration. The need for initial conditions, specifically the initial position and velocity, is emphasized to determine the angular momentum accurately. There is confusion regarding the interpretation of the force and its relation to charge, with a consensus that mass is more relevant for calculating motion. Ultimately, the integration of force with respect to time is necessary to find momentum, but the force is expressed as a function of position, complicating the integration process.
fer Mnaj
Consider the force ##
\vec{F}(\vec{r}) = (−kq/r^2 +β^4/r^5) ˆr ##
which affects an electron with load e. Calculate the torque that F exerts on e and the angular momentum
of the particle.
τ= r x F L= r x p
Is it correct to say that that τ=0 since r has the same directacion as F??
and for \vec{L} que need to find \vec{p}
So I thought solving this dif equation
## \int dp/dt =−kq/r^2 +β^4/r^5##
Do you agree in the path I am going?
I do not agree with the direction you are going. The dif equation you have is incorrect: ##dp/dt## is a force; ##m\int dp/dt## is nonsense.
It looks like you have a central force here and the expression you provide is probably an electric field, not a force. What do you know about the torque that results from a central force or field for that matter?
To find the angular momentum, a velocity at some point is needed. You do not provide that information.
I do not understand "to which an electron is attached load e". Please explain what you mean.
Likes etotheipi
Im studyin mechanics, so I don't think is related directly with electromagnetism
The torque in central force is zero.
Ive corrected m, I was thinking in order to get velocity from that force I need to integrate it
fer Mnaj said:
Homework Statement:: Consider the force ##
to which an electron is attached load e. Calculate the torque that F exerts on e and the angular momentum
of the particle.
That description is unintelligible.
Does it mean the force acts on an electron of charge -e? But if it is a force, we don't care about the charge, we need the mass.
A force acting directly on a particle would lead to a linear acceleration, not to an angular acceleration, nor to a velocity (unless we know how long it acts), nor an angular momentum.
Presumably this is a translation. You will need a better one.
Likes etotheipi
I agree with the comments above, and the problem statement in its current form is quite baffling.
From what we have to go on, what you have here (as mentioned above) is a central force, i.e. something of the form ##\vec{F} = F_r(r) \hat{r}##. Central forces have the special property that they constitute no torque about the origin of the coordinate system:$$\vec{\tau} = \vec{r} \times \vec{F} = r\hat{r} \times F_r(r) \hat{r} = rF_r(r) \hat{r} \times \hat{r} = \vec{0}$$And if you know that ##\vec{\tau} = d\vec{L}/dt = \vec{0}##, then you can deduce that the angular momentum of the particle is a conserved quantity of motion.
But to find out what the angular momentum of the particle actually is, you need to specify the initial conditions in the form of ##\vec{r}(0)## and ##\vec{v}(0)##.
changed the statement, and you are right in the first thing you said. In this case we are talking about a central force, so no angular acceleration as you say.
But we know that ##\vec{F} = d \vec{p}/dt ## so i hoped we could get the velocity by integrating
Yes, but your problem is that to get p by integrating F you'd need to integrate wrt t and the force is given as a function of r.
So what else can you do?
  • · Replies 17 ·
15K
  • · Replies 71 ·
  • · Replies 45 ·
