Finding area by integration problem
  • Thread starter Thread starter lionely
    Area Integration
The problem involves a parabola described by the equation y = 6x - x^2, which intersects the x-axis at points O and A. The task is to demonstrate that the area under the curve divides the area of triangle OAT into two parts in the ratio of 2:1. Participants are exploring the areas related to the triangle and the curve, as well as the tangents at points O and A.
  • Mixed
  • Participants discuss various methods for calculating the areas involved, including integration of the tangents and the area under the curve. There are questions about the correctness of the areas calculated and how they relate to each other.
There is an ongoing exploration of the relationships between the areas calculated. Some participants are questioning the methods used to find the areas and whether certain areas should be included or excluded from the calculations. Guidance has been offered regarding the need to separate the areas under different tangents and the implications of the ratios derived from the areas.
Participants are working with specific area values derived from integration and are attempting to reconcile these with the geometric properties of the triangle and the curve. There is a noted confusion regarding the integration limits and the areas represented by the tangents.
lionely
The parabola y = 6x - x^2 meets the x-axis at O and A. The tangent at O and A meet at T. Show that the curve divides the area of the triangle OAT into two parts in the ratio 2:1.
Here is my working with my sketch. So I thought I should find the area bounded the Tangent at either A or O and the x-axis to find the area of the triangle . So I integrated from x=6 to x=0 and got 108m^2.
I also wanted to check it another way so I found the coordinates of T(3,18) and used that to find the area of an isosceles triangle the normal way, but I got 54m^2. So I am a bit lost now.
And just to check something I found the area bound by the curve and the x-axis from x = 6 to x =0 and got 36m^2.
I don't know what to do with that 36m^2 yet.
I know 108:54
is 2:1... but I don't think that's the correct method.
So you have two areas, you know that one of them is twice the other, and you also know what their sum is.
Try to write this information with equations.
Hold on I actually have three areas there. Should I ignore the 54m^2?
The 54m^2 is a mistake, somehow you only accounted for half of the triangle
(I don't know where you went wrong because you didn't show how you got it).
Oh okay sorry. Area bounded the curve I'll call it C and area of Triangle AOT. C+AOT = 36 + 108 = 144
and AOT = 3C
108 = 3(36).. Hmmm so what should I do now?
The OP doesn't "know" this about the two areas; he has to show this. Here's from post #1.
Exactly what did you integrate here? Please show your work.
54 is the correct area for a triangle with base = 6 and altitude of 18. :smile:
That's the correct area under the parabola between x = 0 and x = 6.
Hold on to it and don't lose it.
I know 108:54
If the curve divides the area of triangle OAT into two parts with ratio 2:1, then this means that 2:1 represents the ratio of the area of the triangle which is not under the parabola to the area which is under the parabola.
You've found the area under the parabola. What is the area under the triangle OAT but also not under the parabola? What is the ratio of these two areas?
and AOT = 3C
I don't know what you are doing here, but you are getting colder, very much colder. :cool:
You should show your work.
I integrated the equation of the tangent at A ; y = 36 -6x from x = 6 to x = 0. Also I integrated the equation of the tangent at O ; y = 6x for the same interval. Got 108m^2 in both cases. I was doing this because I thought the areas under either one of these curves would be the area of the triangle.
Okay, so the curve split the area of the triangle into an Area above the curve and one below it.
area of the triangle under the curve would be 36m^2.
Area above the curve would be = Area of triangle - Area below the curve = 54- 36 = 18m^2
Area of Triangle below the curve:Area of Triangle Above the Curve
36:18
2:1.
Thank you.
Hold on I will take a picture of my other work to show you what I did.
But why is the integral that gave me 108m^2 wrong?
Because you're integrating under a single tangent over the whole interval. (You're taking the area of a large right triangle.) You would want to integrate under one tangent for part of the interval and the other tangent for the other part.
The OP knows what they are trying to show, my point was just that they should say it with equations...
Oops.
That's the tricky thing about this triangle. The two sides of the triangle are expressed by different equations, so you can't integrate the equation for one tangent over the entire interval and expect to get the correct area under the triangle. :frown:
I just tried it over when I integrate the tangent at A from x=6 to x =3 I get 27 and when I integrate the tangent at O from x=3 to x= 0 I also get 27. So I see the 54m^2.
But I still don't fully understand why if I use the tangent at A and use the whole interval, I get 108m^2. Do you have another example of this?
Ohhhhhhhh. Oh okay
But if you write what you're supposed to prove as an equation, you're tacitly assuming that the relationship holds, not showing it.
