Finding centripetal acceleration for a 4 N pendulum bob
5 replies · 7K views
tdreceiver17
An object weighing 4 Newtons swings on the end of a string as a simple pendulum. At the bottom the swing, the tension in the string is 6 Newtons. What is the magnitude of the centripetal acceleration of the object at the bottom of the swing.Centripetal Acc. = v^2/r Sum of forces = T+Ac=mg?Attempt
-T-mg=Ac?
-6-4 = Ac
I don't know where to go from here.
Newton's second law says
$$\sum \vec{F}_i = m\vec{a}.$$ The centripetal acceleration is not a force. It's an acceleration. It goes into the righthand side of F=ma. The tension and the weight go into the lefthand side. Try again and pay attention to the sign of T and mg when summing the forces.
So I set it up as Sum of forces = T-mg=Ac
6-4=Ac
2?
Closer. The lefthand side is correct, but the righthand side isn't. You can't add up a bunch of forces and then set the result to something that isn't a force. ##a_c## is the centripetal acceleration; it's not a force. It's the ##a## in ##ma## on the righthand side.
ah my bad I was correcting it as you answered .
so is it 2=mAc
so its 2 g ? the answer choices only come in a number times g
Not quite. You need to figure out what the mass of the object is from its weight.
