Finding Characteristic Depth of Strip Foundation
To find the characteristic depth of the equivalent soil strip for analyzing horizontal vibrations of a strip foundation, it is essential to transfer vertical stress to horizontal stress. The vertical stiffness of the soil is given by K=1.6*G/(1-v), where G is the shear modulus and v is the Poisson's ratio. The horizontal stiffness can be calculated using the formula Khorizontal = Kvertical * (1 + v) / (1 - v). After determining the horizontal stiffness, it can be used to calculate the characteristic depth of the equivalent soil strip. This approach is crucial for accurate analysis of foundation vibrations.
Zouatine
vibration of soil , get the sttifness of soil
Boussinesq solution k=4GR/1-v
hello everyone!
i have some problem in solution of this problem should i transfert the vertical stree to the horizontal stress and solve it ?
problem :
The equivalent static stiffness of the soil as an infinite elastic half-space under an infinite strip foundation is given in the vertical direction for a unit length of the foundation as:
static vertical stiffness K=1.6*G/1-v where
G: is the shear modulus of the soil ,
v : is the poisson ration of the soil
question:
Assuming an exponential increasing width ,
find the characteristic depth of the equivalent soil strip for the analysis of the horizontal vibration of the foundation.
thank you
Yes, you should transfer the vertical stress to the horizontal stress in order to solve the problem. You can use the following equation to calculate the characteristic depth of the equivalent soil strip for the analysis of the horizontal vibration of the foundation: Khorizontal = Kvertical * (1 + v) / (1 - v) where Kvertical is the vertical stiffness of the soil, and v is the Poisson's ratio. Once you have calculated the horizontal stiffness, you can then use it to calculate the characteristic depth of the equivalent soil strip.
  • · Replies 46 ·
  • Poll Poll
  • Poll Poll
35K
