Finding coefficient of friction.
25 replies · 7K views · last reply
amazondog
Hello, How do i find coefficient of friction knowing only mass, velocity and incline for a inclined plane?
That's a very ambiguous question.
Mass of what? Velocity of what? Initial velocity or final velocity? Any information on acceleration? Is the velocity constant?
A biker going up a hill
Mass = 98.7kg
Constant velocity = 5.95m/s
So there is no acceleration.
If memory serves all that really matters is the mass... the coefficient of friction is multiplied with the normal force. Given that there's no acceleration the only forces in play are the normal force and the force of gravity.
How do you find the force that is needed to go up the hill at the same velocity?
You need to sum all the forces and get some equations to find mu. It would be easy if the cyclist was on flat land, then it would just be
[tex]\mu F_N-F_g=0[/tex]
But since he is on an incline you need to find the component of the gravitational force that is in the same direction as the normal force... and then plug that into find [tex]\mu[/tex].
Edit: You need to know the inclination angle of the hill. I don't know if that was given to you or not.
I see what you're getting at. I just tried doing it and I don't know how velocity comes into play.
umgcos(theta) - gcos(theta) = 0
That would be a very small number...
Mass = 98.7kg
It cannot go up the hill with constant velocity unless there is a force acting on it.
Do you know this force?
Nasu, no i am not given an Fa.
All I have is: A biker rides up an 9.75degree hill at a constant speed of 5.95m/s. The biker and bicycle together have a mass of 98.7kg.
Find the coefficient..
What force does the system need to make the biker go up the hill at the same velocity..
What must the bikers power output be in order to go up the hill at the same speed.
Thanks guys I really appreciate it.
Then something is wrong. If in the first case it goes up, why do they ask then to find the force "to make the biker go up the hill at the same velocity.."?
You could solve the problem if in the first place it goes DOWN the hill with constant velocity. You don't need any other force besides weight and friction for this.
Then it makes sense to ask what extra force is required for it to go up.
Maybe there is some error in text with the problem. Or you misread it.
Sorry, my bad I re-wrote the question without it in front of me. It is going Down and it asks for the rest when it goes up. But how do i find the coefficient?
When the bike goes up the hill, the force that counteracts the weight component down the plane IS the static friction force between the rear tire and the road, which must be equal and opposite to the weight component down the plane. This is the only way a non-rocket powered vehicle can move ...if no friction, the wheels just spin in place. No matter what speed, this force is the same, but the power delivered by the cyclist will be different for different speeds. I don't see anything about the bike going down, you should post the question as written. You can't find the coefficient of friction, only the friction force, which I think it what the problem is asking for. Rolling and axle friction should be ignored, i guess.
Ok, the question as written is:
Question:
A bicyclist is traveling down a hill which has a 9.75 degree incline at a constant velocity of 5.95m/s. The mass of the cyclist and bike combined is 98.7kilograms.
- What is the coefficient of friction of the surface the biker is traveling on?
- What force is needed to go up the hill at the same speed, 5.95m/s.
- What power output must the cyclist generate to go up the hill at the same velocity.
When the bike goes down hill with constant velocity , the friction (uphill, along the plane) must be equal to the component of the weight that acts downhill, along the plane.
This equation will provide the value of the friction coefficient.
Do you know how to write the expressions of these forces?
amazondog said:
umg = mgsin(theta ?
Thanks for clarifying the question. Your equation is incorrect, but you already answered part a in your post #6, so you must have done something right at that time. For part b, nasu has already given you some great hints in posts 14 and 18. Then move onto part c.
Ok, so the coefficient of velocity is tangent to the path. That makes sense.
Maybe if you read again and reformulate.
Do you mean the coefficient of friction is equal to the tangent of the angle of the path?
For the force required to go up the hill is it
Fa - Ff = FN
Facos(theta) - umgcos(theta) = mgsin(theta)
I think i GOT the force required to go up the mountain. Can someone please verify?
Fa - Ff - F// = 0
Fa - umgsin(theta) - mgsin(theta) = 0
Solve for Fa.
Fa - Ff - F// = 0
Solve for Fa.
almost. The friction force is not umgsin theta...your geometry and trig is a bit off..,, it's umg (_?__)theta.
