Finding COM, and inertia my answers don't make sense?
  • Thread starter Thread starter amyparker30
    Inertia
The discussion focuses on finding the center of mass (COM) and rotational inertia of a system comprising four masses: m1=2.5kg, m2=5kg, m3=2.5kg, and m4=5kg. The correct approach involves calculating the COM using the formula Xcom = (m1d1x + m2d2x + m3d3x + m4d4x) / M, where M is the total mass. The rotational inertia about the x-axis is calculated using ICOM = Σmiri2, leading to a final COM position of (Xcom, Ycom, Zcom) and a rotational inertia of 60 kg·m².
  • Understanding of center of mass (COM) calculations
  • Knowledge of rotational inertia concepts
  • Familiarity with mass distribution and coordinates
  • Basic algebra for solving equations
  • Study the derivation of the center of mass formula in multi-body systems
  • Learn about rotational inertia calculations for different shapes and axes
  • Explore the impact of mass distribution on the center of mass
  • Practice problems involving COM and inertia in physics textbooks
Students in physics courses, particularly those studying mechanics, as well as educators looking for effective methods to teach COM and rotational inertia concepts.
amyparker30
Finding COM, and inertia please help my answers don't make sense??
Find the center of mass of the object shown in the figure below?
LINK TO FIGURE:
http://s1168.photobucket.com/albums/r497/amy_parker1/?action=view&current=Untitled.jpg
1. Find the center of mass of the object shown in the figure below.
2. Calculate the rotational inertia of the object about the x-axis.
3. From this value, deduce the rotational inertia of the object about an axis parallel to the x-axis, and going through the center of mass.
m1=2.5kg , m2=5kg, m3=2.5kg , m4=5kg
COM
Inertia?
for COM I got 2
Hi amyparker30! Where are your answers? Where is your working?
ok, my answers are totally wrong but for COM 1 got (2(2.5+5+2.5+5))/15 = 2
ICOM=Rotational Inertia = 2^2(2.5+5+5+2.5) = 60
i bet these are 100% wrong what should I do, my teacher wouldn't help me and the people from class just skipped this question :(
Ok first you need to understand the COM formula and see how it works. Basically you need to specify a coordinate to tell where the COM is. That means you need to find the center of mass in the x direction, y direction, and z direction of the system or object.
So we start by separating everything in components( x, y and z). Let's do the x direction first.
We let d_{nx} represent the distance in the x direction for each particle (n=1,2,3,4)
Then
X_{com} = \frac{m_2 d_{2x}+m_3 d_{3x} + m_1 d_{1x}+m_4 d_{4x}}{M}
where M is the total mass. Note that
d_{2x}=d_{1x}=0
and
d_{3x}=d_{4x}=2 m
Similarly for y:
Y_{com} = \frac{m_2 d_{2y}+m_3 d_{3y} + m_1 d_{1y}+m_4 d_{4y}}{M}
Note that
d_{2y}=d_{3y}=0
d_{1y}=d_{4y} = 2 m
Similarly for z:
Z_{com} = \frac{m_2 d_{2z}+m_3 d_{3z} + m_1 d_{1z}+m_4 d_{4z}}{M}
But Note that
d_{1z} = d_{2z} = d_{3z} = d_{4z} = 0
then
Z_{com} = 0
Then at the end you get the COM to be at (X_{com},Y_{com},Z_{com})
Now try to plug in the numbers and see what you get. (Easy! =))
Do the same thing for the next part (moment of inertia), first understand the formula/equation and just follow it slowly.
I think the first part of this question would be a good one for a multiple choice test. :smile:
By symmetry, the CoM of the two equal masses m1 and m2 is mid-way between them. Likewise, the CoM of the equal mass pair m3 and m4 is mid-way between m3 and m4. And you wouldn't believe our luck :wink: but those two CoM locations coincide!
So that surely must be the CoM for the 4 bodies.
  • · Replies 42 ·
