Finding Complicated Inverse Functions
The discussion revolves around the methods for finding complicated inverse functions, particularly through calculus techniques such as differentiation and integration. Participants explore the applicability of these methods to various functions, including trigonometric and polynomial functions, and consider the challenges associated with non-elementary inverses.
  • Some participants propose using the derivative of an inverse function, expressed as dy/dx = 1/(dx/dy), to find inverses of complicated functions.
  • One participant suggests that implicit differentiation may be necessary to express arcsin(x) as an integral, raising questions about the clarity of the original inquiry.
  • Another participant expresses skepticism about the effectiveness of integrating the inverse of the derivative in complex cases, particularly for functions like arcsin.
  • A participant shares a method involving the intersection of a curve with a line to numerically find inverses, noting that this approach may yield multiple values for non-one-to-one functions.
  • There is a discussion about the potential utility of Taylor Series in finding inverses, although some participants caution against relying on integration for non-elementary inverses.
  • One participant questions the existing formula for finding inverses, emphasizing the need to know the inverse to find its derivative, and seeks examples of common and advanced procedures for finding inverses.
Participants express differing views on the effectiveness and applicability of various methods for finding inverse functions. There is no consensus on a single approach, and multiple competing ideas remain under discussion.
Participants note limitations in existing methods, such as the requirement of knowing the inverse function to apply the derivative formula effectively. There is also mention of challenges posed by non-elementary inverses and the complexity of integrating certain functions.
This discussion may be of interest to those studying calculus, particularly in the context of inverse functions, as well as individuals exploring advanced mathematical techniques for function analysis.
JungleJesus
We have a formula for the derivative of an inverse function:
dy/dx = 1/(dx/dy).
Just how useful is it?
Say we want to find the inverse of a complicated function, f(x), on an interval (a,b) on which f(x) is one-to-one. Can we use integration to find such a function?
Example: Say we didn't know much about the function h(x) = sin(x), but wanted to express its inverse as an integral (this was my inspiration for the idea). How could this be done?
More importantly, this would apply to functions like F(x) = x*e^x. Its inverse, W(x), is important in several applications. Say I choose the branch on (0, infinity). Could I express this branch (or any other I choose) as an integral of well-defined functions?
What do you mean "express its inverse as an integral?"
If you want to find the derivative of an inverse, implicit differentiation(or similar variations) is sometimes the only way.
To express arcsin(x) as an integral, one would find its derivative, and say arcsin(x) = ∫ darcsin(x) or ∫ sqrt(1-x2)-1 dx.
Is that what you mean, or do you want to know how to do implicit differentiation?
OH! You mean find the inverse by differentiating, the integrating the inverse of the derivative. That's a very clever idea! But, unfortunately, in the hard cases like arcsin, it won't get you anywhere.
In the case of sin(x), you would get arcsin(x).
[tex]d(sinx) = cosx dx[/tex]
[tex]\frac{d(sinx)}{dx} = cosx[/tex]
[tex]\frac{dx}{d(sinx)} = secx = \frac{1}{\sqrt{1 - x^2}}[/tex] The rightmost being the most common form of the derivative of arcsin(x)
[tex]\int \frac{dx}{d(sinx)} = \int secx = \int \frac{1}{\sqrt{1 - x^2}} = arcsin(x) + C[/tex] A facepalm would be appropriate here. :-p
Yes. That's exactly what I'm talking about. I want to investigate a general method of finding inverse functions using calculus. For the trig functions, this is easy due to right-triangle trigonometry and the inverse function rule for derivatives. Unfortunately, in its present form, the inverse function rule only works if you know the inverse function at a "deeper" level. I want to actually produce analytic inverse functions on a particular interval. The simplest case I can think of is a strictly monotonic polynomial like [tex]f(x) = x{3}+x{2}+x[/tex]. This inverse is tough to find, but if I could set up an integral that equals this inverse, I would be happy.
Once I can find inverses of one-to-one functions, I can restrict the domains of any differentiable functions until they are one-to-one on an interval, and work from there.
There is one method I can think of, which involves the intersection of a curve with a line. say you have [tex]y = f(x)[/tex]. Switch the x and y so that [tex]x = f(y)[/tex]. Now, x is a function of the independent variable y, which produces an "inverse graph". A line parallel to the y-axis would now be considered "horizontal" in this context. Find the intersection(s) [tex]f(y) = c[/tex] where x = c. x is the argument of the inverse function of f(x). The values where f(y) = c are the values of the inverse function.
This is only a numerical method, and will give several values for inverses of functions that are not one-to-one. My hope is that it could shed some light on my greater problem.
Thanks for reading my post. Any help will be appreciated. :biggrin:
Have you learned Taylor Series? It seems to accomplish what you're attempting. Not to be a cynic, but I'm pretty sure that when trying to apply this to functions with non-elementary inverses you'll end up just integrating to that inverse(ei the non-elementary inverse will be the only function with the derivative in question). It does have application in finding inverses of functions with elementary inverses, but I, for one, would prefer to stay as far away from integrating (3x2+2x+1)-1 as possible.
I like the idea of series, but I don't think they would be applied in that way exactly. Integrating (3x^2 + 2x +1)^-1 would not give the inverse of f(x) = x^3 + x^3 + x.The existing formula requires that the inverse be known to find the derivative. Once you have the derivative, you can integrate it to find the inverse (a moot point). I'm wondering if I can sidestep this fact.
What is known about finding inverses? What are some examples of common and advanced procedures? This might be a launching point.
  • · Replies 25 ·
