FInding current in parallel and series circuits
In summary: V and the voltage drop across the 3 ohm resistor would be 4.5V. In summary, the net resistance in the circuit is 2.5 ohms, the current through the 4 ohm resistor is 1.5A, and the voltage drop across the 3 ohm resistor is 4.5V.
rocky4920
a. What is the net resistance in the circuit?
b. What is the current through the 4 Ω resistor?
c. What is the voltage drop across the 3 Ω resistor?
R12 = R1 +R2
R34 =R3 + R4
1/Rt = 1/R12 + 1/R34
I3=I4
a) R12 = 2+ 3
R 12= 5 ohms
R34 = 4+1
R34 = 5 ohms
1/Rt =1/5 + 1/5
1/Rt = 2/5 ohms
Rt/1 = 5/2 ohms
Rt= 2.5 ohms
b) I3 =I4
I3 = 1.5 A
c) For parallel circuits, voltage is the same across. However, with two series made up in the parallel, my formula does not seem to be correct. For instance, to find V4, V =IR... V= 1.5 (1) = 1.5 V
V3 = IR ... V3= 1.5(4) = 6 V. Following this way, the voltage will not be same throughout the circuit. I am asking for some guidance on finding the voltage and solution for part c.
Thank you.
Image upload didn't work. Be sure it's in PDF or JPEG format... :smile:
Sorry about that! Image above.
Thanks, but what is the battery voltage? Sorry if I'm missing it...
There was no battery voltage given in the problem.
You don't need the battery voltage to answer the questions.
Your answers for a and b are correct.
For c... There are two strings of resistors in parallel with the battery. Both strings are 5ohms. They both have the same voltage across them. The current in one is known. So what is the current in the other?
Likes rocky4920 and berkeman
Ok so would the current for R1 R2 be the same for R3 R4 being 1.5 amps? Therefore, making R1, R2, R3, and R4 V= IR V= (5 ohms) (1.5 A) V= 7.5 V at each throughout circuit.
The battery voltage must be 7.5V. but check what they asked you for in c.
Yes the current through the string R1 and R2 is same as R3 and R4.
V= IR V= 1.5 (3)
V= 4.5 V for voltage drop for 3 ohm resistor.
Correct
1. What is the difference between parallel and series circuits?
In a parallel circuit, the components are connected in separate branches, allowing current to flow through each branch independently. In a series circuit, the components are connected in a single loop, so the current flows through each component in succession.
2. How do you calculate the total current in a parallel circuit?
The total current in a parallel circuit is equal to the sum of the currents in each branch. This can be calculated using the formula: I(total) = I(1) + I(2) + ... + I(n), where I(n) is the current in the nth branch.
3. How do you calculate the total current in a series circuit?
The total current in a series circuit is equal to the current in any one component. This is because the current is constant throughout a series circuit, and the same current flows through each component.
4. What is the effect of adding more resistors in a parallel circuit?
As more resistors are added in a parallel circuit, the overall resistance decreases. This is because the current is divided among the branches, reducing the resistance in each branch.
5. How does the voltage affect the current in a series circuit?
In a series circuit, the voltage across each component is equal to the total voltage of the circuit. As the voltage increases, the current also increases, following Ohm's law (V=IR).
