Finding dH/dt with the chain rule for composite functions
  • Thread starter Thread starter twoflower
twoflower
Hi all,
we were given some recommended home excercises and since we hadn't been given the right results, I'm curous if I'm doing it right:
1. Find [itex]\frac{dH}{dt}[/itex], where
[tex] H(t) = sin (3x) - y[/tex]
[tex] x = 2t^2 - 3[/tex]
[tex] y = \frac{t^2}{2} - 5t + 1[/tex]This is what I did:
[tex] \frac{dH}{dt} = \frac{\partial H}{\partial x}\frac{du}{dt} + \frac{\partial H}{\partial y}\frac{dv}{dt} = 12t\cos (3x) - t + 5[/tex]
Which seems kind of strange to me. Should I replace x with t? It would be this:
[tex] \frac{dH}{dt} = 12t\cos (6t^2 - 9) - t + 5[/tex]
Is it ok?
Thank you.
Yes, it's fine.
But you should have had dx/dt ,not du/dt, and dy/dt, not dv/dt, in the expression for dH/dt.
Why did it seem strange to you ?
Fermat said:
Yes, it's fine.
I'm sorry, I forgot to mention that I defined
[tex] u(t) = 2t^2 - 3[/tex]
[tex] v(t) = \frac{t^2}{2} - 5t + 1[/tex]
So which form is ok? The first or the second?
I find the first one strange because of the mixing of x and t.
OK.
I'm not sure why you defined u and v like that but your mixing of symbols like that is a bit confusing and your differential eqn is wrong the way it is written.
By that I mean ...
[tex]\frac{dH}{dt} = \frac{\partial H}{\partial x}\cdot\frac{du}{dt} + \frac{\partial H}{\partial y}\cdot\frac{dv}{dt}[/tex]
is just plain wrong where it has written,
[tex]\frac{\partial H}{\partial x}\cdot\frac{du}{dt}[/tex]
You should have,
[tex]\frac{\partial H}{\partial x}\cdot\frac{dx}{dt}[/tex]
or
[tex]\frac{\partial H}{\partial u}\cdot\frac{du}{dt}[/tex]
The [tex]\partial u[/tex] should sort of "cancel" with [tex]du[/tex] to give[tex]\frac{\partial H}{dt}[/tex] so that you have [tex]\frac{dH}{dt}[/tex] on one side of the "=" sign and [tex]\frac{\partial H}{dt}[/tex] (twice) on the other side, making both sides consistent with each other.
So, the form of your differential eqn should be either,
[tex]\frac{dH}{dt} = \frac{\partial H}{\partial x}\cdot\frac{dx}{dt} + \frac{\partial H}{\partial y}\cdot\frac{dy}{dt}[/tex]
or
[tex]\frac{dH}{dt} = \frac{\partial H}{\partial u}\cdot\frac{du}{dt} + \frac{\partial H}{\partial v}\cdot\frac{dv}{dt}[/tex]
depending upon what definitions (u = f(t) or x = f(t)) you are using.
You are finding dH/dt, which is the rate at which H varies as t varies. i.e. dH/dt is a function of t, so should be expressed in terms of t.
You can work out things using x and y,or u and v (sometimes using a substitution can simplify working) but your final result shoud be converted to give an expresion that involves t only.
HTH
