Finding dy/dx from e^(2x) = sin(x+3y)
  • Context: Undergrad
  • Thread starter Thread starter lostintranslation
13 replies · 10K views
lostintranslation
I need help with this problem.
Find dy/dx if e^2x = sin(x+3y)
Any help would be great!
I began by taking the natural log of both sides...which may not be correct??
Thanks!
Thanks!
That's certainly one way to do it: you get 2x= ln(sin(x+3y)).
Of course, you will have to use the chain rule on the right side when you differentiate now.
Couldn't you have used the chain rule on both sides of the equation the way it was written? What is [itex]\frac{de^u}{du}[/itex]? What is
[itex]\frac{de^u}{du}\frac{du}{dx}[/itex] if u= 2x?
So [tex]e^{2x} = \sin(x+3y)[/tex] When you take the natural log of both sides you get: [tex]\ln e^{2x} = \ln\sin(x+3y)[/tex] or [tex]2x = \ln\sin(x+3y)[/tex]. Now use implicit differentiation to find [tex]\frac{dy}{dx}[/tex]
Ok, right.
So
2x = ln (sin(x+3y))
Then if you take the derivative...
2 = (1/sin(x+3y)) * cos (x+3y) * 3 * dy/dx
So dy/dx = 2(sin(x+3y))/ 3(cos(x+3y)) ?
Is that right?
yes that is correct.
Thanks so much! Does that simplify any farther?
I guess you could write it as [tex]\frac{2\tan(x+3y)}{3}[/tex]
Ok good! That is what I thought.
You have been so helpful! Thanks!
I have a couple more [shorter] questions, however don't feel obliged to respond if you don't want to...
1. Find dy/dx of y = x^5 * 7^x
2. Find dy/dx of y = (1/2) ^ x
3. Find dy/dx of y = (cosx) ^ x
1. Use the chain rule. [tex]y = x^{5}7^{x}[/tex]. [tex]y' = x^{5}(7^{x}\ln 7) + 7^{x}(5x^{4})[/tex]
2. [tex](0.5)^{x}[/tex] is just [tex](0.5)^{x}\ln 0.5[/tex]
3. I'll let you do this one
In general, [tex]\frac{d}{dx} a^{u} = a^{u}\ln a \frac{du}{dx}[/tex]
Right, right. That rule would make those very easy! Thanks bud! :-p
I am still having trouble with the cosine one however. I apparently need to use multiple steps to find the derivative.
Mistype in 2: [tex](0.5)^x[/tex] is just [tex]e^x\ln 0.5[/tex].
By the way, I don't see anything gained by taking the logarithm in the first problem you posted. It is just as easy to differentiate both sides of
e2x= sin(x+ 3y) the way it stands:
2e2x= cos(x+ 3y)(1+ y') so
[tex]1+ y'= \frac{2e^{2x}}{cos(x+3y}}[/tex]
and
[tex]y'= \frac{2e^{2x}}{cos(x+3y}}- 1[/tex]
Is that right?
Nope, that's {B]not[/B] correct!
The above line should read:
[tex]2 = \frac{\cos (x + 3y)}{\sin (x + 3y)} \left( 1 + 3 \frac{dy}{dx} \right)[/tex]
You forgot the (1 + 3 dy / dx)
How on Earth can that be called correct? :confused:
That's also a mistype.
0.5x = ex ln(0.5)
By the way, there's a typo there:
e2x= sin(x+ 3y)
Differentiate both sides with respect to x gives:
2e2x= cos(x+ 3y)(1+ 3y')
To find dy / dx of y = cosxx. Just do the same:
cosxx = ex ln(cos(x))
Or, you can do it a bit differently:
y = cosxx
Take the logarithm of both sides gives:
ln y = x ln(cos x)
Then you can differentiate both sides with respect to x, and see what you get.
sorry for the typos
Thanks HallsofIvy and VietDao for correcting me.
