Finding E field inside a sphere with charge proportional to radius
1 reply · 14K views · last reply
Vapor88
First time poster here! EDIT: SOLVED!
Thanks, I figured out from the related links at the bottom of the page. >_>b
Find the electric field inside a sphere which carries a charge density proportional
to the distance from the origin, [tex]\rho[/tex] = kr, for some constant k.
[tex]\oint E.da[/tex]
[tex]a = 4 \pi r^2/3[/tex]
[tex]da = 4 \pi r^2[/tex]
[tex]\rho = kr[/tex]
[tex]E = q/(r^2 4 \pi \epsilon _0)[/tex]
Where q = charge inside
[tex]\oint E \bullet da = \int q/(r^2 4 \pi \epsilon _0) \bullet 4 \pi r^2[/tex]
The 4 pi r^2 terms cancel, leaving on the right
[tex]q/ \epsilon_0[/tex]
Substitute rho into the eqn. as to integrate all dimensions of the sphere
[tex]\int \rho d \tau / \epsilon_0[/tex]
Here's where I get stuck, I know that
What do I do with [tex]d \tau[/tex]? I'd imagine that it'd be easiest to do in spherical coordinates, so do I just add dr, dtheta, drho?
Also... How do I put a dot into this LaTex thing?
Thank you!
You do not know the electric field, but you can calculate it by applying Gauss' law.
Because of symmetry, E depends only on r and is the same along a sphere of radius R. The surface integral for a sphere of radius R is equal to Q/epszilon, where Q is the charge confined inside the sphere
[tex]4 \pi R^2 E(R) = \frac{4 \pi}{\epsilon}\int_0^R{kr*r^2dr=\frac{4\pi}{\epsilon}k R^4/4 \rightarrow E(R)=\frac{kR^2}{4\epsilon}[/tex]
ehild
