Finding eigenvalues and eigenvectors of a matrix A
2 replies · 2K views
Rubik
Find the eigenvalues and eigenvectors of the matrix A = [2, 1; 8, 4]
det(A - lambda I) = 0
After expanding using the formula I have the equation (2 - [itex]\lambda[/itex])(4 - [itex]\lambda[/itex]) - 8
Which gives [itex]\lambda[/itex] = 0, 6 (Should I be worried that I got a zero in my answer?)
Then substituting the values for lambda back into the problem and using (A - [itex]\lambda[/itex]I)v = 0
For [itex]\lambda[/itex] = 6
[-4, 1; 8, -2] * [a; b] = [0; 0] and I get the eigenvector a[1; 4] from (-4a + b = 0)
For [itex]\lambda[/itex] = 0
[2, 1; 8, 4] * [a; b] = [0; 0] I get a second eigenvector of a[1; -2] from (2a + b = 0)
Did I get the right eigenvalues and corresponding eigenvectors?
Yes, you did. And it's easy for you to check as well. A*[1;4] should give you 6*[1;4] and A*[1;-2] should give you 0*[1;-2], right? Does it work?
Notice that the determinant of the matrix is 2(4)- 1(8)= 0. Since the determinant of a matrix is the product of its eigenvalues, 0 must be an eigenvalue.
