Finding electron density from Hall voltage
  • Thread starter Turion
    Homework
4 replies · 2K views · last reply
Turion
Text problem: A flat copper ribbon 0.330 mm thick carries a steady current of 50.0 A and is located in a uniform 1.30-T magnetic field directed perpendicular to the plane of the ribbon. If a Hall voltage of 9.60 μV is measured across the ribbon and d= 1 mm, what is the charge density of the free electrons?
$$Δ{ V }_{ H }=\frac { IB }{ nqt } \\ 9.6*{ 10 }^{ -6 }=\frac { 50*1.3 }{ n*e*3.3*{ 10 }^{ -4 } } \\ n=1.28*{ 10 }^{ 29 }\quad electrons/{ m }^{ 3 }$$
mfb said:
You can use WolframAlpha to check calculations like that.
I thought the method was wrong because it gives us d=1mm but we don't use it in our calculations.
