Finding equation with zeroes and max value
  • Thread starter Thread starter Drake M
    Max Value
The discussion revolves around finding the equation of a parabola with zeroes at 5/2 and -3/2 and a maximum value of 4. The user initially calculated the vertex and attempted to derive the equation in factored form but arrived at a different result than the answer sheet. Key points include the understanding of the optimal value as the maximum y-value at the vertex and the correct substitution into the factored form. The user realized the error stemmed from not simplifying the factors correctly during substitution. Ultimately, the correct equation is confirmed to be equivalent to the answer sheet's version, highlighting the importance of careful algebraic manipulation.
Drake M
[Note: Thread moved to this forum by a mentor]
Hi all, the full question is:
A parabola has zeroes at 5/2 and -3/2 and has an optimal value of 4. Determine equation of the parabola in factored form.
So I started out with 4 as my y-value on my vertex then took the zeroes(5/2 and -3/2), added them and divided by 2 to get the x-axis for the x-value in the vertex.
Subbed in (.5,4) into factored form with the zeroes,
y=a(x-r)(x-s)
4=a(.5-5/2)(.5-(-3/2)
4=a(-2)(2)
4/-4=a
-1=a
So the equation should be y=-1(x-5/2)(x-(-3/2) or y=-1(2x-5)(2x+3)
The answer sheet says its y=-1/4(2x-5)(2x+3)
I have similar numbers but don't know where I went wrong. Any help is appreciated
y=a(x-r)(x-s)
4=a(-2)(2)
4/-4=a
-1=a
How did your second equation derive? What does an optimal value of 4 really mean?
isnt optimal value max value of y which would be the vertex
Drake M said:
isn't optimal value max value of y which would be the vertex
I suppose so, which would follow from 4 being the maximum value. The other common possibility being that it's a minimum, but then of course that would imply that there are no x-intercepts.
It may be a maximum, or a minimum. Anyway, how do you usually find it and where? All you know is the y value of 4 I guess.
Where does this line come from?
But maybe you are using another method than me. However, to find your deviation from the given result I need to know better what you are trying to do.
EDIT: Ok, I got it now. Everything is fine but the way you got rid of the factor 1/2 in the parenthesis. You multiplied twice by two and didn't correct it outside.
Thanks for the help guys, a buddy of mine solved it and showed me how. I wasnt simplifying x-5/2 into 2x-5 and x--3/2 into 2x+5 before is subbed in my vertex values and that's where I went wrong
Those answers are equivalent. except for the part crossed out
