Mentor
- 20,989
- 2,934
A fine choice for an image. Now, note the layout. Imagine that the middle resistor R3 is removed for now (This resistor is called the "bridge" component, since it forms a bridge between the middles of the two parallel branches). On the left there are two resistors R1 and R4 that form a potential divider across the 24 V supply. On the right side is a similar pair, R2 and R5, which form another potential divider for the 24 V. So without R3 there you could easily determine the potentials at those two middle nodes with a voltage divider formula used on each pair.
Now, the potential that a potential divider produces at its center node depends upon ratios. If the components of two different potential dividers have the same ratio, both potential dividers will produce the same voltage division. In the above circuit, if R1/R4 = R2/R5 then the middle nodes of the bridge would be balanced (Ignore the actual values that were included on the picture, we're just looking at theory right now). This is the sort of symmetry that you look for in bridge circuits that can be helpful: Equal component ratios on either side of the bridge let you know that the unloaded (no R3) potential dividers would produce the same potential.
Now, if that were the case (equal potentials) then laying R3 back into the circuit would do nothing! It would have the same potential at both of its connections, so no current could flow through it. The circuit would be undisturbed in any way by reconnecting R3. So R3 might as well not be in the circuit (when the bridge is balanced).
Once you have digested that, see if you can follow jbriggs444's advice and match the components from your circuit to their equivalent locations on this new bridge diagram. For bonus points, determine if your bridge is balanced!
