Finding equivalent capacitance between A and B with isolated component
67 replies · 16K views · last reply
gracy said:
But then I get confused which one will be denominator and which one will be numerator.
It doesn't matter which should be numerator or denominator. Just pick any ratio on one side, use the same on the other side.
Let say if I would have taken
C1/C2=C4/C3
After putting the values
I could have thought the bridge is not balanced.
You want to see if the two voltage dividers in the bridge circuit will produce the same voltage division. So a simple procedure is to make ratios of the components that make up each voltage divider. Compare the ratios. You can't go wrong if you select corresponding pairs (use symmetry and common sense).
You mean if I have selected C1 as numerator for one potential divider I shall select the one which is adjacent to it but at the other side of bridge as numerator of second potential divider,Right?
C1/C2=C4/C3
You can call the two resistors on one side as 'upper' and 'lower'. So, upper/loewer on one side=upper/lower on the other side.
Its just a memory trick..To understand the bridge balance conceptually, you should analyse it using voltage divider.
logspot.com%2F-jehPxcGkMYs%2FTfgZWoCbTII%2FAAAAAAAAAQY%2F4eEQrl6bCcQ%2Fs1600%2Fbridge%2Bresistor.gif
upper/lower on one side=upper/lower on the other side.And if bridge is of this sort
upper left/upper right on one side=lower left/lower right on the other side
Right. Once you're fluent, you won't need this trick.
