Finding Equivalent Resistance in a Combination Circuit
7 replies · 6K views · last reply
Gemy4
What is the equivalent resistance of the combination of identical resistors between points a and b in the figure below?
Series= Req= R1 + R2 + R3 etc
Parallel = Req= (1/R1 + 1/R2 + 1/R3 etc)^-1
Req= R1 + (1/3R) + R3
I don't know what to do from here.
  • Circuit schematic with terminals a and b at the ends of a horizontal wire. Three identical resistors labeled R in a column form a parallel block between two vertical bus wires, with a series resistor labeled R on each side.
Parallel= Req= R1 + R2 + R3 etc
Series= Req= (1/R1 + 1/R2 + 1/R3 etc)^-1
These equations are wrong. The correct ones are
series= Req= R1 + R2 + R3 etc
Thank you is this correct I only have one more submission
I tried that answer already and it says "Check the syntax of your response".
Check the second term in the equation.
The second term is right if he means 1/3 R and not 1/(3R). However, what is R1 and R3 in terms of R? Can you simplify the equation?
There are no numerical values for R. I asked my friend and the correct answer is 2 + (3)^-1.
Not sure how she got it.
I know there are no numerical values for R, which is why I asked how R1 and R3 relate to R. Look at the diagram and figure out what R1 and R3 are in terms of R.
