Finding Initial Velocity and Angle in 2D Kinematics Problem
19 replies · 9K views · last reply
CocoonOHorror
A softball is hit over a third baseman's head with some speed v-sub0 at an angle theta above the horizontal. Immediately after the ball is hit, the third baseman turns around and begins to run at a constant velocity V = 7.00m/s. He catches the ball t=2.00sec later at the same height at which it left the bat. The third baseman was originally standing L=18.0 m from the location at which the ball was hit. Find v-sub0 Use g=9.81 m/s^2 for the magnitude of the acceleration due to gravity. also find theta.
x =( initial velocity times cos theta)* time
y = initial velocity times sin theta)* time - .5GT^2
i don't understand how to solve an equation with 4 variables and i only have values for 2 of them. i have time = 2 seconds, and distance = 32 meters. how do i get an angle and an initial velocity?
There are two equations and two unknowns. Hint: What's y, measured from the starting height?
CocoonOHorror said:
is it 9.8 meters?
No. How does the initial height compare to the final height?
it seems like you just use the dude running at 7 m/s for 2 seconds to get the total distance (18m + 14m) but i guess that's not the right way to go about it?i really wish my physics prof spoke english!
they are the same.
No, that's perfectly correct. That gives you the value for x you'll need in the first equation.
What about y?
CocoonOHorror said:
they are the same.
Yes! So, if you measure from the starting point, what's y? (What's the change in height?)
zero?
so i have:
32=(initial velocity*cos theta)*time
and
0= (initial velocity*sin theta)*time - .5GT^2
right?
but now what?
wait, i have 16 = initial velocity * cos theta
and 9.8 = initial velocity * sin theta (or is it 4.9/2 = initial Velocity * sin theta ?)
(i think)
now what?
Play around with those equations and see if you can isolate one of the variables. There are several ways to go. (Try division.)
OK, maybe 16/cos theta = 9.8/sin theta?
im so lost...
is it an easy Trigonometric solution? I am in Trig/precalc algebra in one class and we just started the Trig half, so maybe I am not familiar with a function to equate Sin/Cos?
im so lost...
You're not that lost. Multiply both sides by sin theta. (What other trig function appears?)
does Tan theta = 9.8/16 ?
am i on the right track?
holy mackeral! thanks Doc Al, i really appreciate the help!
