Finding integrading factor for differential equation
19 replies · 3K views
Lily@pie
The differential equation:
(1-y2) dx + (1-x2) dy = 0
the integrating factor is of the form μ(x,y) = f(xy). Find f
2. The attempt at a solution
I have tried many times to get a function of (xy) such that the LHS of the differential equation to be exact.
I have tried the integrating factor 1/[(1-y^2)(1-x^2)] and it works... but it is definitely not a function of the term (xy)...
Any hints on how should I find it? Or is there any formal way to find it?
You know that ##f(xy)(1-y^2)\,dx + f(xy)(1-x^2)\,dy## is supposed to be an exact differential, so what does that tell you about how ##M(x,y) = f(xy)(1-y^2)## and ##N(x,y) = f(xy)(1-x^2)## are related?
Yes. If you do that, you'll eventually end up with a differential equation for f(xy) you can solve.
That is actually the part where I am stuck. The differential equation will be a partial differential equation right? But I hv not learned that before... Or it is the same as the ordinary differential equation?
No, you should end up with an ODE. Show us your work.
My(x,y)=Nx(x,y)
fy(x,y)(1-y2)-2yf(xy) = fx(x,y)(1-x2)-2xf(x,y)
Is the above correct? As I don't know how to continue from here onwards.
You need to evaluate the partial derivatives. Think of it as f(u) where u=xy. What's ##\partial f/\partial x## equal to?
will ∂f/∂x be (df/du)y?
Right, which is f'(xy)y.
f'(xy)(x-xy2)-2yf(xy) =f'(xy)(y-x2y)-2xf(x,y)
f'(xy)+[itex]\frac{2x-2y}{x-xy^{2}-y+x^{2}y}[/itex]f(xy)=0
Is this the ODE that I need to solve to find f(xy)? It feels like I'm getting something but I don't know how to start :bugeye:
Simplify.
Oh, so i get
f'(xy) + [itex]\frac{2}{1+xy}[/itex]f(xy)=0
So I'll get f(xy)=[itex]\frac{1}{(1+xy)^{2}}[/itex]
YAY! Then I found the integrating factor...
Thanks A LOT!
For my own practice, I tried to solve the differential equation
(1-y[itex]^{2}[/itex]) dx + (1-x[itex]^{2}[/itex]) dy = 0
And the solution I got is
[itex]\frac{y^{2}-1}{y(1+xy)}[/itex]+[itex]\frac{1}{y}[/itex]=D
where D is some arbitrary constant
Is this correct?
Hi Lily@pie! :smile:
(I can see how you got it, but it only works for the dx, not the dy :redface:)
nooo …
the solution obviously is going to be symmetric in x and y …
so what's the simplest symmetric numerator you can think of? :wink:
What do u mean by it only works for the dx and not dy?
What do u mean by symmetric numerator? y=x?
No, that's not what "symmetric in x and y" means. It means that if you were to swap "x" and "y" you would get exactly the same formula. For example, both [itex]x^3+ y^3[/itex] and [itex]x^2+ 3xy+ y^2[/itex] is "symmetric in x and y". [itex]x^3+ y^2[/itex] and [itex]x^2+ 3x+ y^2[/itex] are not.
Ohhh... so the simplest one will be something like x+y?
But i still don't understand what does it mean by the solution only works for dx and not dy...
I think your solution is correct, but you can simplify it a bit by putting everything over a common denominator.
