Finding linear acceleration of a rolling log down a ramp
1 reply · 11K views · last reply
Mdhiggenz
A uniform solid cylindrical log begins rolling without slipping down a ramp that rises 28.0 above the horizontal. After it has rolled 4.20 m along the ramp, the magnitude of its linear acceleration is closest to
What I did was
mgh=1/2mv^2+1/2Iω^2
mgh=1/2mv^2+1/2[1/2mr^2]ω^2
v=rω
mgh=1/2mv^2+1/4mv^2
√4/3gh=v
solved for v and got 7.41m/s
I then used the constant acceleration equations
vx^2=vo+2aΔx
solving for a and got 6.54 which is the incorrect answer.
Where did I go wrong
Thank you!
Hi Mdhiggenz,
The problem is in your first calculation, where you come up with 7.41m/s. Your manipulation of the algebra looks correct to me (double check!), but at the very last step you seem to have used h=4.20m. The problem says that the log moved 4.20m along the ramp, which means it would have descended 4.20m*sin(28deg), which is the value you should use for h. Does this fix your problem?
Hope this helps,
Bill Mills
