Finding local maximums and minimums
  • Thread starter Thread starter wildcat12
    Local
To find the cubic function g(x) = ax^3 + bx^2 + cx + d with a local maximum of 2 at x = -9 and a local minimum of -7 at x = 8, start by setting up equations based on these conditions. The function values at these points provide two equations: g(-9) = 2 and g(8) = -7. Additionally, the derivatives at these points yield two more equations: g'(-9) = 0 and g'(8) = 0. This results in a system of four equations that can be solved to determine the coefficients a, b, c, and d. Solving this system will yield the desired cubic function.
wildcat12
Find a cubic function g(x)=ax^3 +bx^2 +cx +d that has a local maximum value of 2 at -9, and a local minimum value of -7 at 8.
I thought i would find the derivative and set it equal to zero, but i do not know what to do from there
Well, to find the values of a,b,c,d you'll need some constraints on those numbers
1) You know that when you plug 2 in your poly, you should get -9. When you plug -7 in, you would get 8. These deliver two equations.
2) When you derive your function, you know that when you plug 2 in, you get 0. When you plug -7 in, you would get 0 to. These deliver another two equations.
So you have 4 equations. You should be able to solve this system without problems...
So plug those numbers in for x? correct?
yes!
Awesome. i don't know why i didnt get that
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
