Finding location of an object as a function of time
In summary, the problem involves a rock being thrown off a cliff at an angle θ to the horizontal. By using Newton's second law, the location of the rock as a function of time in horizontal and vertical Cartesian coordinates can be found. The distance of the rock from its starting point, r(t), is a function of x(t) and y(t), where x(t) is the horizontal location and y(t) is the vertical location. To find the maximum value of θ for which r will continually increase, one can manipulate the equation for r(t) to isolate v0cosθt and determine the conditions for it to continually increase.
NCampbell
a) Starting From Newtons second law, find the location of the rock as a function of time in horizontal and vertical Cartesian coordinates
b) If r(t) is the distance the rock is from its starting point, what is the maximum value of θ for which r will continually increase as the rock flies through the air?
F=ma
a) So as the question asks, I start with Newtons second law, that being, f=ma so Fnet=dp/dt (where p=mv), Knowing this am I just to integrate m*dv/dt in vector form?
So I would get something like r(t) = v(t)-1/2a(t)^2 i + v(t)-1/2a(t)^2 j?b) haven't got that far
If a is not constant, then x(t) (or y(t)) is NOT equal to v(t) - 1/2a(t)^2, you actually have to integrate to figure out what the position function is.
BTW it's confusing because you use parentheses around t to indicate function notation in some places, and seemingly to indicate multiplication in other places. So, I'm not entirely sure what exactly you've written.
I am sorry I am not grasping the concept of integrating vectors could you provide some direction?
Basically, the components evolve with time independently so that:
r(t) = x(t)i + y(t)j
and,
x(t) = vx(t)dt
y(t) = vy(t)dt
Similarly:
vx(t) = ax(t)dt
vy(t) = ay(t)dt
From Newton's second law:
ax(t) = Fx(t) / m
ay(t) = Fy(t) / m
In all of the above, boldface quantities are vectors, subscripted quantities are vector components, and parentheses indicate function notation.
In case it wasn't clear from the above, the velocity, acceleration, and force vectors are of course given by:
v(t) = vx(t)i + vy(t)j = dr/dt
a(t) = ax(t)i + ay(t)j = dv/dt
F(t) = Fx(t)i + Fy(t)j
So, the summary is that to integrate or differentiate vectors, you can just integrate or differentiate component-wise.
I'm assuming you've been given F(t), otherwise I don't know how you'd solve the problem.
Thank You Cepheid! that cleared things up for me I was lost after my lecture on vector calculus today amongst the different notations and how each of the components are affected differently, and no I wasn't given F(t) just that a rock was through off a cliff at angle (theta) from the horizontal
Oh okay. So F(t) = 0i - mgj
(gravity: constant with time, and only vertical).
The angle gives you initial conditions on the velocity (i.e. you know both components of v at t = 0). Two initial conditions (initial velocity v(0) and initial position r(0)) are necessary in order to solve the problem, because otherwise when you integrate, you get a whole family of functions as solutions (represented by the arbitrary constants "C" that you get when you integrate each time). The initial conditions help you to find what the value of "C" is in this situation when you integrate.
I have this exact same problem (we are probably in the same class :)) and I am stuck on part b). I would greatly appreciate any insight into solving this. Here is the full question:
A rock is thrown from a cliff at an angle θ to the horizontal. Ignore air resistance.
a) Starting From Newton's second law, find the location of the rock as a function of time in horizontal and vertical Cartesian coordinates.
b) If r(t) is the distance the rock is from its starting point, what is the maximum value of θ for which r will continually increase as the rock flies through the air? (Suggestion: write out an expression for r2, using the results of part a), and consider how it changes with time).
My expressions for part a) are:
x(t) = v0cosθt +x0
y(t) = v0sinθt - 4.9t2 + y0
[itex]\vec{r}[/itex](t) = [itex]\hat{x}[/itex]x(t) + [itex]\hat{y}[/itex]y(t) = [itex]\hat{x}[/itex](v0cosθt +x0) + [itex]\hat{y}[/itex](v0sinθt - 4.9t2 + y0)
So for part b) I have:
r2 = x2 + y2 = (v0cosθt +x0)2 + (v0sinθt - 4.9t2 + y0)2
I am just unsure what I am supposed to do with an expression for r2 and how that relates to finding θ.
This isn't actually an answer (sorry), but...
r represents distance from the starting point. It's a function of x2 and y2. Just thinking about this problem, if you simply hold the rock and let it fall, than θ would be 0 and so would r. If you threw it exactly horizontal, than θ would be 90 degrees, and I'd empirically expect that r2 would reach it's maxima.
Of course, proving that is the question here. My thinking off the cuff here is to use fairly standard algebra to resolve the problem. Manipulate the equation so that you have v0cosθt by itself on the right (or left, whatever...) side, you know? I may be completely off here, but that's my thinking after having just read this now.
Actually if you dropped the rock straight off of the cliff then θ = -90 degrees (relative to the horizon as it states in the question) and r is a positive number [itex]\leq[/itex] to the height of the cliff that is always increasing with time as the rock falls. The answer definitely is not throwing it exactly horizontal because that means θ = 0 and we are looking for when θ is at the max angle above the horizontal where the distance to the rock is always increasing.
To get a better sense of the question, imagine throwing the rock at about 85 degrees above the horizon. The rock will go nearly straight up at first (i.e. r is increasing with time) but as soon as it reaches its peak height, it will begin to fall again nearly straight down and r will start decreasing with time. We are looking for the max angle where r will always be increasing over time.
That being said, I still don't know how to solve for θ but I do know that it will be somewhere in the range of ~45 degrees or so.
Right, because... well, because. That makes intuitive sense to me, as well. As a matter of fact, I'm fairly sure that 45 degrees will end up being the answer.
You could try brute forcing the problem for the moment, just to make sure we're on the correct path. Stick the formula into a spreadsheet. I'm fairly convinced that this comes down to standard algebra (in that you simple need to manipulate the formula and solve for theta).
If we know r (and using polar coordinates) that x=rcos[itex]\theta[/itex] and y=rsin[itex]\theta[/itex] then isn't [itex]\theta[/itex]=arctan(y/x)? I am having a difficult time with this question so I am not entirely sure on what to do either.
i have a question, if i got vector r= (something)x-hat+(something)y-hat, how would i counvert it into polar form? i was thinking that if we find the first derivative of the polar form of r, the distance will be contineously increasing if the first derivative is greater than 0?
To convert to polar form we use r=sqrt(x^2+y^2) and theta= arctan(y/x) where x and y are your x and y components
then how to start part b?
I am not sure? I don't see the connection between r^2 and how to find theta that way, are you also in this class?
The distance r = |r| =(x² + y²)½ is the distance of the object from the origin. If r is to be always increasing with time, then this suggests that the derivative of r with respect to time must always be positive (for all t), does it not? I think that is the key idea you need in order to get part (b). The problem may have instructed you to work with r² instead because it makes the math easier. I think that if r is always increasing then so is r².
The theta you are referring to here is the theta-coordinate, in a polar coordinate system. In general, this depends on time (since x and y depend on time). However, the problem want you to find the theta at launch, i.e. the initial value of theta at t = 0. This is just one particular value of theta at one particular time, and can be regarded as a constant in the equations. Vector Boson had the right idea.
what class is this?.. anyway, i have the same questions. i think we should find|r|, and solve it with r^2 is more convinient. since r^2=x^2+y^2 and solve implicitly? but i got a mess and can't really solve this. all the 4 questions i have give me headache...
Related to Finding location of an object as a function of time
What is the purpose of finding the location of an object as a function of time?
The purpose of finding the location of an object as a function of time is to track the movement and position of the object over a period of time. This information can be used for a variety of applications, such as predicting future positions, analyzing patterns of movement, and understanding the behavior of the object.
What factors affect the accuracy of determining the location of an object as a function of time?
There are several factors that can affect the accuracy of determining the location of an object as a function of time. These include the precision of the measuring instruments used, the level of environmental interference, and the speed and direction of the object's movement.
What methods are commonly used for finding the location of an object as a function of time?
Some common methods for finding the location of an object as a function of time include GPS tracking, motion sensors, and video analysis. Each method has its own advantages and limitations, and the most appropriate method to use will depend on the specific needs and context of the situation.
How can the data obtained from finding the location of an object as a function of time be analyzed?
The data obtained from finding the location of an object as a function of time can be analyzed using various mathematical and statistical techniques. These can include plotting the data on a graph, calculating the speed and acceleration of the object, and identifying patterns or trends in the movement.
What are the real-world applications of finding the location of an object as a function of time?
The ability to accurately find the location of an object as a function of time has many real-world applications. These include navigation and tracking systems, sports analysis, transportation planning, and scientific research in fields such as physics, biology, and astronomy.
