Finding mass of ice in latent heat of fusion problem
The discussion revolves around a physics problem involving the cooling of cola using ice, where the goal is to determine the mass of ice needed to achieve a specific temperature change. Participants outline the necessary energy calculations, including the heat required to warm the ice, melt it, and then heat the resulting water. The user struggles with rearranging the complex equation to isolate the mass of ice, seeking clarification on the steps involved. After some back-and-forth, they express confusion over the signs in their calculations, leading to a negative mass result, which indicates a misunderstanding in the setup or calculations. The conversation highlights the importance of careful equation manipulation and understanding thermodynamic principles in solving such problems.
aussie-girl
The question is: a 6 pack of cola cans contains m grams of liquid. you want to put ice into a perfectly insulated box to cool it down from Ts to Tf. The ice initially has temp Ti. So (a)how much ice would you need as a minimum. (ignore presence of cans and final state of ice will be water). (b) calculate the mass of ice initially at -5 deg celsius needed to cool 2.1kg of canned cola from 23 deg celsius to 4 deg celsius.
specific heat of water = 4.18J
Lf of water = 333.55Jkg-1
mass(cola) x C (water) (Tf - Ts) = mass(ice) x C(ice) (0 - Ti) + mass(ice) x Lf + mass(ice) x C(water) (Tf - 0)
I've worked out that the amount of energy needed to melt 'm'kg of ice = m(ice) x Lf(water) or Q = mL. also that heat lost by cola = heat gained by ice
I realize there are 3 stages involved:
(1) heat needed to raise ice to O deg celsius
(2) heat needed to melt ice
(3) heat needed to raise temp of water (from melted ice) to Tf from O deg celsius.
Then I get lost. How do I find the mass of the ice to begin with? Do I rearrange the equation? If so, I have no idea how to start rearranging a long complex equation like this.
Thank you for any guidance on this.
Welcome to PF!
Hi aussie-girl ! Welcome to PF! :smile:
call the mass of ice M, and write out the equations …
then we'll see how to rearrange them :wink:
Hi tiny-tim, nice to meet you!
So done as suggested and here is the result:
part (a):
m(cola) x C(water) (Tf - Ts) = M(ice) x C(ice) (0 - Ti) + M(ice) x Lf + M(ice) x C(water) (Tf - 0)
part (b):
2.1kg x 4.186 x (4 - 23) = M(ice) x 2.093 x (0 - -5) + M(ice) x 333.55 + 4.186 (4 - 0)
I think I've substituted in the right figures. Please advise how I now proceed?
Thanks, appreciate your time and help!
Hi aussie-girl! :smile:
(i haven't checked your figures, but …)
put M(ice) outside a bracket on the right-hand side …
M(ice) x [2.093 x (0 - -5) + 333.55 + 4.186 (4 - 0) ] :wink:
Hi again
I'm confused by what you said. I can see that you've taken the second M(ice) out of the equation and assume you mean to put that outside a bracket on the right-hand side? but that doesn't make sense to me. are you showing me what you mean by this:
M(ice) x [2.093 x (0 - -5) + 333.55 + 4.186 (4 - 0) ] but that can't be right because the second M(ice) is missing.
I've been thinking about this and I can't figure it out. maybe I'm just being thick but it is 3.30am over here! can you please explain more? I'm not expecting you to solve it for me but I need more explanation.
Thanks again...
ah yes … i should have noticed that …
the clue's in the name, isn't it? :biggrin:
Ma + Mb = M(a + b) …
(oh, and I should have written M(ice) x [2.093 x (0 - -5) + 333.55] + 4.186 (4 - 0) :redface:)
that may not mean anything to you right now, but …
get some sleep! :zzz:
… and it'll all be clear in the morning. :smile:
Hi again
Just before I go to bed (I need to know this stuff for a paper that's due tomorrow!) can I see if this is what you mean:
2.1kg x 4.186 x (4 - 23) = M(ice) x [2.093 x (0 - -5) + 333.55] + 4.186 (4 - 0)
-167.021 = M(ice) x 362.2
so to get M(ice) on its own via rearrangement, you get:
M(ice) = -167.021 / 362.2 = -0.46
I think I'm going crazy :'( this doesn't seem right! the answer is a negative. God I don't know! I think I'll go to bed now...
thanks again tiny-tim.
  • · Replies 17 ·
