Finding max/min given contraint
  • Thread starter Thread starter ultra100
4 replies · 2K views
ultra100
Find the product of the maximum and minimum values of the function f(x, y) = xy
on the ellipse (x^2)(1/9) + y^2 = 2
I tried soving using lagrange multiplier and got:
fx = y - (2/9)(x*lambda)
fy = x - 2y*lambda
flambda = (x^2)(1/9) + y^2 - 2
then I set these = 0, but my answer came out wrong.. any suggestions for figuring out the min/max?
For y I'm getting, [tex]y = \pm 1[/tex]
The way I set this up was as follows:
Define:
[tex]f(x,y) = xy; g(x,y) = \frac{x^{2}}{9} + y^{2} = 2 \Rightarrow h(x,y,\lambda) = f(x,y) + \lambda g(x,y)[/tex]
(Note that the sign in front of [tex]\lambda[/tex] does not matter)
So let's take our partials, we get:
[tex]\frac{dh}{dx} = y + \frac{2 \lambda}{9}x, \frac{dh}{dy} = x + 2 \lambda y, \frac{dh}{d\lambda} = \frac{x^2}{9} +y^2 - 2[/tex]
We know that each of those partials vanish i.e. we can set each to 0.
The first one gives us
[tex]9y = -2 \lambda x[/tex]
and the second one gives us
[tex]\frac{x}{y} = -2 \lambda[/tex]
And by simple substitution we get:
[tex]9y^{2} = x^{2}[/tex]
So let's substitute it into our 3rd equation to get:
[tex]y^{2} + y^{2} = 2[/tex]
Which yields our desired result of [tex]y = \pm 1[/tex]. Now we can plug this into our g(x,y) to get [tex]x = \pm 3[/tex]
Note that it doesn't matter which value for y we pick therefore our solution set will be:
[tex](1,3), (1,-3), (-1,3), (-1,-3)[/tex]
Now if you don't want to do this using Lagrange Multipliers, we can just realize that we can rewrite our g(x,y) as
[tex]y = \pm \sqrt{2 - \frac{x^2}{9}}[/tex]
and now we can substitute this into our f(x,y) get an equation of one variable i.e.
[tex]\bar{f}(x) = \pm x \cdot \sqrt{2 - \frac{x^2}{9}}[/tex]
Now we can proceed using the techniques you learned in Calculus 1 (I'm going to use Maple because I'm lazy)
> a:=x*sqrt(2-x^2/9);
a := [tex]\frac{1}{3} x \sqrt{18 - x}[/tex]
> solve(diff(a,x)=0,x);
-3, 3
Note that choosing the negative root produces the same results.
what equations are you using to get y = to +/- 1?
Refresh your page :)
Thanks! This helps a lot
