Finding maximum height of a string before it goes slack
The problem involves a mass suspended by a light elastic string, which is pulled down and released. The goal is to determine the maximum height the mass can be pulled down before the string goes slack, considering the effects of air resistance. The discussion centers around the conditions under which the string remains taut and the mathematical modeling of the system using a differential equation.
  • Participants discuss the derivation of the differential equation of motion and the implications of the condition bc² < 4g. There are attempts to find the maximum displacement and clarify the definitions of variables such as µ and ν. Questions arise regarding the initial conditions and the interpretation of when the string goes slack.
Participants are actively engaging with the mathematical aspects of the problem, exploring different interpretations of initial conditions and the implications of the string's natural length. Some guidance has been offered regarding the use of initial conditions and the general solution form, but there is still uncertainty about deriving the maximum height and the conditions for the string remaining taut.
There is an ongoing discussion about the definitions of variables and the physical meaning of the conditions under which the string goes slack. Participants are questioning the assumptions made about the initial setup and the implications of the mass's motion on the string's tension.
green-beans
A mass m is suspended by a light elastic string. When the mass remains at rest it is at a point 0, which is a distance a + b below the point from which the string is suspended from the ceiling, where a is the natural length of the string. The mass is pulled down a distance h below 0 and released from rest. The moving mass is subject to air resistance of magnitude cv per unit mass, where c is a positive constant and v is the speed of the mass.
Show that if bc2 < 4g then the largest value of h such that the string never becomes slack is h = be(πµ/ν), where µ = c/2 and ν = 1/2√{(4g/b) − c2}.
I deduced the differential equation of motion in terms of the displacement x of the mass below 0 (until the string goes slack) to be x'' + cx' + (g/b)x = 0.
bc2 < 4g occurs when the characteristic equation has 2 complex roots λ = (-c/2) ± i{√|c2 - 4g/b|}/2
So, the solution would be
x=e(-c/2)t*(Asin{1/2*√|c2-4g/b|}t + Bcos{1/2*√|c2-4g/b|}t)
Then I tried differentiating the expression and setting first derivative to zero to find the maximum value of x but it did not work as I could not even solve the equation. Also I do not quite understand where π in the answer came from.
I would appreciate if someone could give me some direction on how to do this question.
Thanks!
Thanks!
I think what you have is correct. It must be simpler to set ##\nu =## the complicated expression you get from solving the quadratic. This keeps the algebra simpler.
The next step is to find the coefficients ##A## and ##B##. Why not use the initial conditions ##x(0) = \dot{x}(0) = 0##?
Thank you for your reply! However, I keep on getting that A and B are zero if I use that x(0)=x'(0)=0 and this reduces the whole equation to 0 which is impossible.
You have to define where ##x=0## is. I figured ##x=0## when length of string is ##a+b## ( Ah, the problem statement says so ). That way ##x(0) = -h,\ \ \dot x(0)=0 ## makes more sense.
I think we need to define mathematically what the condition "the string never becomes slack" means. Does it mean (as I assume) that ##x(t)\leq b## because since the system will do oscillation around the point O, if the displacement becomes greater than b then the string will become(at a certain time point) less than its natural size which I suppose that's what slack means.
Apologies, it should be, of course, ##x(0) = h## and ##\dot{x}(0) = 0##.
The other point is that even if you had not been given the definitions of ##\mu## and ##\nu## you should have done this yourself. Once you have solved the characteristic equation, you should have set:
##\lambda = -\mu \pm i\nu##
Or, something similar. Then your general solution is:
##x(t) = e^{-\mu t}(A\cos(\nu t) + B\sin(\nu t))##
Which is much easier to work with, clearer to read and quicker to type into Latex.
Should not ##x(0) = - h## since the mass starts below 0? Also I obtained that A = -h and B= -μh/nu but I don't quite understand how I can now find the greatest value of h. Also, since the string never becomes slack, does it mean that x(t) < 0?
Thanks in advance!
Thanks in advance!
I took downwards to be the positive direction. ##x(0) = -h## will work just as well, as it's the same general solution either way.
The solution will be damped SHM. The mass will move upwards. What is the key factor when it reaches its highest point?
PS The string will go slack if it reaches its natural length of ##a##.
Thank you for your reply! At the highest point its velocity should become 0 so it will not go slack, is it right? If so I will need to solve v=0 as far as I understand. If yes, I then get that sin(nu)t *([μ2h/nu + h (nu)) = 0 but I cannot still see where the given expression for h comes from.
Well, there's only one way that that expression is 0!
Yes, of course, it's when t=pi/nu. However, to obtain the answer from what I got it must be that (x(pi/nu)) = b which I don't quite understand why.
The natural length of the string is ##a##. It is stretched to a length ##a+b## by the mass ##m##. This is the point ##x = 0##. The string is then stretched to a length of ##a+b+h## (that's why I thought ##x(0) = h## was more natural than ##x(0) = -h##, but no matter).
The mass rebounds to its highest point at ##t = \frac{\pi}{\nu}##. If ##x( \frac{\pi}{\nu}) > b## (using your directions), then the mass has rebounded beyond the natural length of the string, which has gone slack (and, in fact, in this case the equations and solution are no longer valid). So, ##x(\frac{\pi}{\nu}) = b## is the maximum rebound.
That's the logic of the question.
Oh right, this makes sense! Thank you so much - I now understand it :)
  • · Replies 26 ·
