Finding Normal Vector and Tangent Plane at a Given Point
  • Thread starter Thread starter charmedbeauty
    Normal Vector
5 replies · 2K views
charmedbeauty
help me find this normal vector!
Find a normal vector n and the equation of the tangent plane to the surface S at the point x0
S: z=ln(x2+3y2)
x0=(2,-1,ln7)
ok so I have this general formula from the textbook.
z= z0+Fx(x0,y0)(x-x0)+Fy(x0,y0)(y-y0)
and n=(Fx(x0,y0) , Fy(X0,Y0) , -1) respectively.
so using these
S: z= ln(x2+3y2)
let u=x2+3y2
z=ln(u)
dz/du=(1/u) (u')
Fx(x,y) = d/dx(u)/u = 2x/(x2+3y2) = 4
Fy = d/dy (u)/u = 6y/ (x2+3y2) = -6
z= ln7 + 4(x-2)-6(y+1)
z= ln7 +4x -6y -14
ln7 +4x -6y -14 -z = 0
so n =(4,-6,-1)T
but they have 4x-6y-7z-14+7ln7=0
and n= (4, -6, -7)T
?? I am not sure what I have done wrong but it looks very close to what they have.
any help is appreciated.
Check your numerical results of the substitution of x0,y0 here. :)
ohh no (-1)2≠-1.
Thanks a bunch uart!
Do you think you could give me a hint in the right direction for this one?
z2+x2+y2=1
x0=(1/3 , 1/2, √23/ 6)
If I do it the usual way and I solve for z, I get a negative sqrt term so I don't think that is the right approach.
there is some inequalities I can see but I don't think that helps
I think its a sphere but that doesn't really help me either.
please help. Thanks.
If [itex]z^2+ x^2+ y^2= 1[/itex] then [itex]z= \pm\sqrt{1- x^2- y^2}[/itex]. That is not a "negative squareroot" it simply means that [itex]x^2+ y^2[/itex] cannot be larger than 1. And that must be true geometrically because this is the surface of a sphere of radius 1.
But it is not necessary to solve for z. If a surface is given by F(x, y, z)= constant, then the gradient, [itex]\nabla F[/itex] is a normal vector at each point on the surface. Here [itex]F(x, y, z)= x^2+ y^2+ z^2[/itex] so that [itex]\nabla F= 2x\vec{i}+ 2y\vec{j}+ 2z\vec{k}[/itex]. At the given point, that is [itex](2/3)\vec{i}+ \vec{j}+ \sqrt{34}/3\vec{j}[/itex] so the tangent plane at that point is [itex](2/3)(x- 1/3)+ (y- 1/2)+ \sqrt{34}{3}(z- \sqrt{34}/6)= 0[/itex].
ok I think that should be a √23 /6 not √34 /6
but that is a really convenient way of doing that. thanks a lot.
but for some reason in their answer they have multiplied it by three i.e.
2x +3y+√23z -6 = 0
does this not change the normal vector in a geometric way?
since they have n=(2,3,√23)T
and not n=(2/3,1,√23 /3)T
Thanks.
