Finding Null Space of a Matrix with Trigonometric Equations
  • Thread starter Thread starter indigojoker
    Null space Space
This discussion focuses on finding the null space of a matrix defined by trigonometric equations, specifically the matrix A = \dotx \left(\begin{array}{cc}cos(\beta)&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)\end{array}\right). The user struggles with solving the resulting linear system of equations, ultimately discovering that the null space can be expressed in terms of a free parameter. The discussion highlights the importance of recognizing dependent equations and correctly applying the eigenvalue equation Ax = ax for eigenvectors, rather than the incorrect Ax = x.
  • Understanding of linear algebra concepts, particularly null spaces and eigenvalues.
  • Familiarity with trigonometric functions and their properties.
  • Knowledge of complex numbers and their manipulation in equations.
  • Experience with solving homogeneous linear systems of equations.
  • Study the properties of null spaces in linear algebra.
  • Learn about eigenvalues and eigenvectors, focusing on their applications in matrix theory.
  • Explore methods for solving systems of linear equations, including substitution and elimination techniques.
  • Investigate the implications of dependent and independent equations in linear systems.
Mathematicians, physics students, and engineers who are working with linear algebra, particularly in applications involving trigonometric functions and complex numbers.
indigojoker
I need to find the null space of:
\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right)
so:
\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right) \binom{x}{y} = 0
I'm not sure how to go about doing this because I've been staring at:
(cos(\beta)-1)x=-sin(\beta)e^{-i \alpha} y
sin(\beta) e^{i \alpha} x = (-cos(\beta)-1) y
for a while now and I'm not sure how to get the x and y values
It's just a linear system of equations, isn't it? How do you normally solve systems of linear equations?
by substitution, but the thing is I keep getting y=0 and x=0
Does the obvious x = -sin(\beta) e^{-ia}, y = cos(\beta)-1 not work?
sure, but i would like to know how to solve for that.
so:
Usually when you solve a problem like this-- i.e. a homogeneous linear system, you're going to end up with the trivial solution (x,y)=(0,0) and a surplus of other solutions with a free parameter.
What you usually do is solve one of these equations and use a variable as a parameter.
For example, if you solve the first equation you've been staring at for x, you get:
x=-\frac{sin(\beta)e^{-i \alpha}}{cos(\beta)-1}y
And hence, you have \binom{-\frac{sin(\beta)e^{-i \alpha}}{cos(\beta)-1}y}{y} as your null-space, y being a free parameter.
You could have just as well have done it for x, with that as the free parameter.
Ofcourse, you could always simplify this.
You can do similarly for the second equation you got and obtain a basis for your null space.
Notice that the two equations are not independent, so the solution, if one exists, would be a line. Such a line has to include the origin, so just eliminate/ignore one of the equations, and what you've got left should describe the line.
thanks for the advice!
In the grand scheme of things, I was trying to find the eigenvectors of:
A=\dotx \left(\begin{array}{cc}cos(\beta)&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)\end{array}\right)
I got eigenvalues of +1 and -1
if we took the -1 case, we have:
\dotx \left(\begin{array}{cc}cos(\beta)+1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)+1\end{array}\right) \binom{x}{y} = 0
my null space would be:
x=\binom{-sin(\beta)}{(cos(\beta)+1)e^{i \alpha}}
However, this does not satisfy the eigenvalue equation: Ax=x\dotx \left(\begin{array}{cc}cos(\beta)-1&sin(\beta)e^{-i \alpha}\\sin(x)e^{i \alpha}&-cos(\beta)-1\end{array}\right) \binom{-sin(\beta)}{(cos(\beta)+1)e^{i \alpha}}=\binom{sin(\beta)}{(-cos(\beta)-1)e^{i \alpha}}
Not sure what this means
It looks correct to me... The relevant equation is not Ax=x, but Ax = ax, where a is the eigenvalue.
  • · Replies 18 ·
