Is Oscillation Amplitude the Same as Displacement?
The discussion revolves around the relationship between oscillation amplitude and displacement in the context of a mass-spring system undergoing angular oscillation. Participants are exploring how to determine the oscillation amplitude given certain parameters, including angular frequency, spring constant, and kinetic energy at a specific time.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the formulas related to kinetic energy and oscillation amplitude, questioning whether amplitude and displacement are equivalent in this context. There is an exploration of using energy equations to solve for amplitude and the implications of time on these calculations.
The discussion is active, with participants clarifying their understanding of the relationship between kinetic energy and amplitude. Some have suggested using the total energy equation to find amplitude, while others are questioning the need for additional information or parameters. There is recognition of the confusion surrounding the definitions and the equations involved.
Participants note the absence of mass in the given problem, which complicates the calculations. There is also a mention of the need to consider the specific time at which kinetic energy is measured, as it affects the interpretation of amplitude and displacement.
erok81
I have a problem where I am given the following values:
Angular Oscillation Frequency which I have assigned to omega
Spring Constant, which is k
The system's kinetic energy in Joules.
Phi is assumed to be 0
I am asked to find the oscillation amplitude at a certain time, t.
I am using two different formulas.
[tex]KE=\frac{1}{2}(kA^{2})[/tex] I am using this one to solve for A.
[tex]x(t)=Acos(\omega t+\varphi)[/tex] Then this one to solve for the oscillation amplitude at time "t"
I am stuck on the oscillation amplitude. I know this is also referred to as A (which is the max amplitude of the object) in my formula, but since it is asking for the amplitude at a certain time, would this be the same thing as x(t), displacement? I've never seen it worded this way, so I am not sure if they are the same thing.
I can provide the values if that will help and I can show my final answer to see if it is correct.
Unless your oscillation is damped, 'A' would be constant. I think they want you to find the displacement at a certain time.
Total energy = 1/2 k A2 = 1/2 kx2+1/2mv2
Yeah, you are right. I read the question wrong. It just wants the amplitude from an energy at time t. But your answer helps because that clears up A.
So with those givens I posted, is it possible to just use KE=1/2kA^2, and then solve for for A? Or do I need anything extra?
Depending on the time t, you will need to use KE+PE = constant which is the equation which I posted and find 'A' from there:
Here is the exact question.
A mass on a spring has an angular oscillation frequency of 2.56 rad/s. The spring constant is 27.2 N/m, and the system's kinetic energy is 4.47J when t = 1.56 s. What is the oscillation amplitude? Assume that φ = 0.00.
At first I some how missed the period and thought the time was referring to the oscillation amplitude. But now that I read it again, I think it's just asking for A. Since I don't know the mass, is it possible to solve it just using the KE=1/2kA^2?
I ended up with 0.5 something meters. (I don't have my paper with me right now, so I can't remember my exact answer)
The total energy of the oscillator is KE+PE = 1/2 kA^2. The potential energy at a given position x is PE=1/2 kx^2. KE at a given time is
KE(t)=1/2kA^2-1/2 k x(t)^2
Supposing that x=A cos (wt), you know everything to get A.
ehild
Hmm...in order to get x, I have to find A first, which is the exact question. I guess that is where I confused. With what I am given, the only thing that makes sense is KE=1/2kA^2.
I don't see why one would need to solve anything related to x=A cos (wt). Since in order to use that I have to know either A or the position, neither of which I have. :confused:
***SEE POST FIVE FOR CORRECT QUESTION. ORIGINAL PROBLEM WORDED INCORRECTLY.***
Oooh...I see I think.
So if I use the total energy) KE(t)=1/2kA^2-1/2 k x(t)^2, I have two unknowns. But I can sub in cos(wt) for x(t). Solving for A I get...
[tex]A=\sqrt{\frac{2KE+k[cos(\omega t)]^2}{k}}[/tex]
Which comes out to be 0.87m for A.
Does that look right?
Except this is where I am confused. Your equation says
Total energy = 1/2 k A^2 = 1/2 kx^2+1/2mv^2
If the total energy is KE=1/2kA^2. I should be able solve from there??
No. You have to sub in Acos(wt) for x(t).
ehild
Oh yeah, duh.
So how about.
[tex]A=\sqrt{\frac{KE}{0.5k-0.5k[cos(\omega t)]^2}[/tex]
That gives me 0.762m.
The part I still don't get is why can't I just solve for the total energy KE=1/2kA^2 since that represents the total energy of the system?
Your result is correct.
"the system's kinetic energy is 4.47J when t = 1.56 s". 1/2 kA^2 is the maximum potential energy which is the same as the maximum kinetic energy, but different from the kinetic energy at t=1.56 s.
ehild
I finally get it. Thanks for including that explanation at the end. That helps me out a ton because now I actually understand why the way I was doing it didn't work.
Thanks again.
ehild
Also note that if energy is conserved then 1/2 kA2 is the total energy of the system (K + U). So erok81 the original equation you supplied for KE is actually, as the other posters have pointed out, the equation for total energy of the system, . I think that's where your confusion arised/arose?
  • · Replies 27 ·
