Finding particular solution yp of given equation
  • Thread starter Thread starter ProPatto16
    Particular solution
13 replies · 8K views · last reply
ProPatto16
y''+2y'-3y=1+xex
ive tried yp=Axex+B
and yp=Ax2ex+Bx
and both don't work. assuming I am doing it correctly.
im given the answer as: 1/3+1/16(2x2-x)ex
suggestions?
thanks
[itex]e^x[/itex] is a solution to the associated homogeneous equation so if the function on the right were just [itex]e^x[/itex] you would have to try [itex]xe^x[/itex]. Because you want [itex]xe^x[/itex], try [itex]Ax^2e^x[/itex] instead.
Thanks guys, LC that makes sense now I see it, I was varying the order of the ex^x but not the 1. Which of course is silly.
heyy...
i tried yp=Axex+Bx2ex and got
after subbing back into y''+2y'-3y
result was A(4ex)+B(8xex+2ex)=1+xex
looking at that i saw i could cancel out constant A by making it Aex
using Aex+Bxxex
after subbing in i got B(8xex+2ex)=1+xex
how can i possibly solve for A or B??
[itex]y= (Ax+ Bx^2)e^x[/itex]
[itex]y'= (A+ 2Bx)e^x+ (Ax+ Bx^2)e^x= (A+ (2B+ A)x+ Bx^2)e^x[/itex]
[itex]y''= (2B+ A+ 2B)e^x+ (A+ (2B+ A)x+ Bx^2)e^x= (6B+ 2A+ (2B+ A)x+ Bx^2)e^x[/itex]
[itex]y''+ 2y'- 3y= [(6B+ 4A)+ 4Bx]e^x= xe^x[/itex]
Solve for A and B.
i don't know how to do the quotes thing so ill copy and paste.
" y′′+2y′−3y=[(6B+4A)+4Bx]ex=xex "
but from the original question... y′′+2y′−3y=xex +1
whered the +1 go?
Because the equation is linear, you can do that separately.
Let y= B. Then y''= y'= 0 so the equation becomes ...
ohhh. I missed that :/
hang around please, gimme 10min to post the way i did it. its slightly different.
y= Axex+bx2ex
y'= A(xex+ex) + B(2xex+x2ex)
y''= A(xex+ex+ex) + B(2xex+2ex+2xex+x2ex)
subbing in
y''+2y'-3y = [A(xex+ex+ex) + B(2xex+2ex+2xex+x2ex)] + 2[A(xex+ex) + B(2xex+x2ex)] - 3[Axex+bx2ex]
= A[xex+2ex+2xex+2ex-3xex] + B[4xex+2ex+x2ex+4xex+2x2ex-3x2ex
= A[4ex] + B[8xex+2ex]
the only thing that differs from your solution is the B parts
it seems like one of my 2xex should only be 2ex so i get 6 and 4 instead of 8 and 2...
I had before, [itex]y′′+2y′−3y=[(6B+4A)+4Bx]e^x=xe^x[/itex]
so you must have 4B= 1 and 6B+ 4A= 0.
yeah i did that part. there just an error in my jumble up there. was hoping you'd see it. but nevermind. thanks for all your help though, much appreciated! :)
yeah... i was right...
to get the correct answer the euqations for A and B should be
8B=1 and 2B+4A=0
gives B = 1/8 and A = -1/16
about that +1 that got left alone... you said we can do that separately...
y''+2y'-3y=1+xex
taking out all differentiable functions leaves 3y=-1 so y= -1/3 + yp ??
