Finding perceived star cluster density using stellar stereography
  • Thread starter Thread starter DivGradCurl
    Integral
18 replies · 14K views
DivGradCurl
"Astronomers use a technique called stellar stereography to determine the density of stars in a star cluster from the observed (two-dimensional) density that can be analyzed from a photograph. Suppose that that in a spherical cluster of radius [tex]R[/tex] the density of stars depends only on the distance [tex]r[/tex] from the center of the cluster. If the perceived star density is given by [tex]y(s)[/tex], where [tex]s[/tex] is the the observed planar distance from the center of the cluster, and [tex]x(r)[/tex] is the actual density, it can be shown that
[tex]y(s) = \int _s ^R \frac{2r}{\sqrt{r^2 - s^2}}x(r)\: dr[/tex]
If the actual density of stars in a cluster is
[tex]x(r)=\frac{1}{2}(R-r)^2[/tex]
find the perceived density [tex]y(s)[/tex]."
I've tried working with the aid of a technical computing software, but it doesn't make things clear to me right now---although I have the solution:
[tex]y(s) = \int _s ^R \frac{2r}{\sqrt{r^2 - s^2}}\: x(r)\: dr = \left. \frac{1}{3}\sqrt{r^2 - s^2} \left( r^2 - 3rR + 3R^2 + 2s^2 \right) -Rs^2 \ln \left( r + \sqrt{r^2 - s^2} \right) \right] _s ^R[/tex]
[tex]y(s)=\frac{1}{3}\sqrt{R^2 - s^2}\left( R^2 + 2s^2 \right) - Rs^2 \ln \left( R + \sqrt{R^2 - s^2} \right) - \left( -Rs^2 \ln s \right)[/tex]
[tex]y(s)=\frac{1}{3}\sqrt{R^2 - s^2}\left( R^2 + 2s^2 \right) + Rs^2 \ln s - Rs^2 \ln \left( R + \sqrt{R^2 - s^2} \right)[/tex]
I couldn't find any reference in my table of integrals to help me understand this better. Maybe you guys can explain me how this integration is carried out. Any help is highly appreciated.
Use the subtitution
[tex]r = s sec\theta[/tex]
you will end up with bunch of integrals of the form
[tex]\int \frac{1}{cos^n \theta} d\theta[/tex] , with n = 2,3 and 4
and these are standard integrals.
Use the subtitution
If I had to guess, I'd think in practice, y(s) is obtained through experiment and then x(s) needs to be determined? I don't know, just think that's how it would be. In that case, you'd handle the equation as a Volterra type integral equation right?
[tex]y(s) = \int _s ^R F(r,s)x(r)dr[/tex]
Can someone here comment about this? Or maybe Thiago can comment about it too.
Thanks,
Salty
Yes,Salty,it's the other way around indeed.Knowing the perceived density,one must find the "real" one,which means solving for "x" from the integral equation you posted.
But in this case,being an elementary one,the physics is turned upside down for the likes of simple mathematics...
Daniel.
Well, thank you guys for the help!
What I can see is that there are two ways to do it:
1. Hyperbolic substitution with [tex]\cosh x[/tex]
2. Trigonometric substitution with "[tex]\mbox{ssec } \theta[/tex]". By the way, don't you mean [tex]\sec \theta[/tex]?
I got to review some of these techniques so that I can do it on my own. Anyway, I now know what direction I should take. Thanks
That was definitely a typo.And it came out twice,since he double-posted the message.It's [itex]\sec \theta[/itex],as it should be...
Daniel.
Wait a minute. We're not done. Can you give some "realistic" perceived data so that I can work on the integral equation (I mean, once I figure out how to solve just the integral with the subs. that were suggested)?
What about a real reference with real astronomical data? Are you familiar with Chandrasachar's study of star brightness in the Milky Way? He solves a beautiful PIDE by infinitely folding an integral! Beautiful. It's ok if you don't want to pursue it. I have time.
Salty
Salty
Just though I'd report the equations I was referring to. Not trying to show off. Just beautiful math and perhaps others will think so too. Here's the original Chandrasachar equation:
[tex]g(u,e)+\frac{\partial g}{\partial u}+\frac{\partial g}{\partial e}=\int_0^1 g(\frac{u}{q},e) \Psi(q) \frac{dq}{q}[/tex]
Actually, he makes some simplifying assumptions in order to reduce it to an IDE:
[tex]f(u)+\frac{df}{du}=\int_0^1 f(\frac{u}{q})\Phi(q)dq[/tex]
The solution to the second problem is very interesting to follow (took me several weeks, I ain't proud).
That was definitely a typo.And it came out twice,since he double-posted the message.It's ,as it should be
It was not a typo. It is [tex]r = s sec\theta[/tex]. You need 's' so that when you factor out 's' you will end up with [tex]s\sqrt{sec^2\theta -1} = s\tan\theta[/tex]
Have a look at the integral again.
Regards.
Note: I accidently double posted it yesterday. How do I delete one if that happens in the future? Thanks.
Send PM to moderator to delete post.
And one more thing:
[tex]s\cdot \sec\theta[/tex] makes as difference compared to what u've written.And if u still don't like the multiplicative dot,u can use the [tex]\times[/tex] sign...
Daniel.
Wasn't easy for me.
Consider:
[tex]\int_x^R \frac{r(R-r)^2}{\sqrt{r^2-x^2}} dr[/tex]
Using [itex]r=xSec(\theta))[/itex] then the integral becomes:
[tex]\int x\sec^2(\theta)(R-x\sec(\theta))^2 d\theta[/tex]
This actually turn out to be manageable yielding:
[tex]xR^2\tan(\theta)-Rx^2[\ln(\sec(\theta)+\tan(\theta))+\sec(\theta)\tan(\theta)]+x^3[\tan(\theta)+\frac{1}{3}tan^3\(\theta)][/tex]
Using a right-triangle to convert [itex]\theta[/itex] back to oposite, adjacent, and hypotnuse and back substituting and then a lot of rearranging, I got (with difficulty) the answer reported by Thiago (just used x to avoid confusion with sec). Where are you anyway, we're not done yet . . . what about a plot? What about the integral transform?
Salty: "Wait a minute. We're not done. Can you give some "realistic" perceived data so that I can work on the integral equation (I mean, once I figure out how to solve just the integral with the subs. that were suggested)?
What about a real reference with real astronomical data? Are you familiar with Chandrasachar's study of star brightness in the Milky Way? He solves a beautiful PIDE by infinitely folding an integral! Beautiful. It's ok if you don't want to pursue it. I have time."
Sorry, but the information in the first post of this thread is all that there is to the problem. Unfortunately, there isn't any real data to look into. In fact, this is just a problem from my calculus book, which only asks for the integral (no plot or transform is required).
I'm not familiar with Chandrasachar's study of star brightness in the Milky Way, but it's always fun to go ahead and learn a bit more. If you have any reading suggestions, please let me know.
Thank you
Thank you
That's Ok Thiago, really just kidding about you doing anything further. I intend to pursue it further but I'll post the transform in the Cosmology group (once I work with it a bit) as it's more appropriate there. Interesting. Will try to find real data. I'm into Astronomy.
Thank You,
Salty
