Finding Phase Constant and air-track glider
  • Thread starter Thread starter Liketothink
    Constant Phase
18 replies · 6K views
Liketothink
An air-track glider attached to a spring oscillates with a period of 2.3 s. At t=0 s the glider is 3.09 cm left of the equilibrium position and moving to the right at 35.07 cm/s.
What is the phase constant? (in degrees)
v0x= -wAsin(ro), x=Acos(ro)
I divided v0x/x=wtan(ro). I solved for angular speed which was 2.73 rad/s. Now I solved for (ro) by taking tan inverse of (v/-wx). I received 73 as an answer and that's wrong. Would you please help me? Thank you.
Since you are to the left, you have to subtract 180. The anwser you came up with is to the right of the equilibrium point.
I minus that by 180 so it's 107 but that's still wrong. What do you think is wrong?
Did you get
[tex]r_{0} = \tan^{-1} \frac{35.07}{3.09 \cdot 2.73}?[/tex]
yeah, I tried that as well which was 76.4751. Then I minus it from 180 so it's 103.525 but that's wrong.
Both 76.47 and 76.47 - 180 have the same tangent. You can see by drawing a pic that the one we want is (76.47 - 180).
-103.5 degrees = -1.807 radians.
is it because it's negative and the distance is negative?
Also, in this case, is angular speed the same as velocity? If I wanted to find the phase at t=0 s would I just need to use wt+ro, w being the velocity?
Yes, the cosine of 76.4 is positive, but the initial distance is negative.
No, angular speed and velocity are different. The angular speed is constant, while the velocity is changing.
v = -Aωsin(ωt + a0)
ok, so for t=.5s I get -102.115 but that's wrong. All I did is wt+constant(-103.48). But that's wrong for some reason. Does the constant change at that time?
Do you get the right answer now? (I'm not sure what you're trying to calculate BTW, did you get the correct answer for the phase constant?)
I got the correct answer for the phase constant but I'm trying the phase for t=.5s. Sorry for the confusion.
Ok, so at t = 0.5, you have ωt + a0 = 2.73(0.5) - 1.806. This is in radians. If you want to convert it to degrees, multiply by 360/2pi.
The question has several parts and it's asking me for the phase at t=.5s. I used the same formula but it's wrong. Could you please let me know what's wrong? thank you.
Ok thank you very much for all your help. I greatly appreciate it.
