Finding phase shift when only initial displacement is given
12 replies · 2K views · last reply
isukatphysics69
Four displacement versus time graphs labelled A to D for horizontal oscillators, each with axes Displacement (cm) and Time (s) from 0 to 20 s, showing sinusoidal curves of differing period and amplitude.
Asin(wt + Φ)
let t = 0
Case A:
-.10 = .20sin(Φ)
sin-1(-.10/.20) = Φ = -0.52
Case B:
.10 = .10sin(Φ)
sin-1(.10/.10) = Φ = 1.57Case C:
-.05 = .05sin(Φ)
sin-1(-.05/.05) = Φ = -1.57Case D:
0 = .20sin(Φ)
sin-1(0/.20) = Φ = 0
Now i think i have to determine which ones are in which quadrant. i have to determine whether to subtract pi or not. But how to determine?​
  • Four displacement versus time graphs labelled A to D for horizontal oscillators, each with axes Displacement (cm) and Time (s) from 0 to 20 s, showing sinusoidal curves of differing period and amplitude.
What was the question? No question was stated. Also, the graph is not clear enough to make out anything.
Four displacement versus time graphs labelled A to D for horizontal oscillators, each with axes from 0 to 20 s and -25 to 25 cm; A has the largest amplitude and longest period, B and C shorter periods, D the shortest period.
Screenshot of a text box with instructions: rank the phase constant of each oscillator, smallest first, with negative phases ranked below positive ones, and answer in the format A < B = C < D with spaces around each inequality sign.
  • Four displacement versus time graphs labelled A to D for horizontal oscillators, each with axes from 0 to 20 s and -25 to 25 cm; A has the largest amplitude and longest period, B and C shorter periods, D the shortest period.
  • Screenshot of a text box with instructions: rank the phase constant of each oscillator, smallest first, with negative phases ranked below positive ones, and answer in the format A < B = C < D with spaces around each inequality sign.
Four displacement against time graphs labelled A to D, each with displacement in cm on the vertical axis from -25 to 25 and time in s from 0 to 20 on the horizontal axis, showing sinusoidal oscillations of differing amplitude and period.
here is a better pic
  • Four displacement against time graphs labelled A to D, each with displacement in cm on the vertical axis from -25 to 25 and time in s from 0 to 20 on the horizontal axis, showing sinusoidal oscillations of differing amplitude and period.
You can see from your graphs which quadrant they are in.
Since you use the sine function, A sin( ωt ), the first quadrant is the section that starts at 0 and rises to A, the second starts at A and falls to 0, the third starts at 0 and falls to -A, and the fourth starts at -A and rises to 0. Equally you can look at the time values: if T is the period, then first quadrant is from t=o to t=T/4, second from t=T/4 to T/2, etc.
Just look at the intercept on the displacement axis and see which part of the cycle it corresponds to.
Graph of one sine wave cycle from t=0 to t=T, with the four quadrants Q1 to Q4 marked, vertical lines at t=T/4, T/2 and 3T/4, and horizontal lines at +A, 0 and -A on the displacement axis.
  • Graph of one sine wave cycle from t=0 to t=T, with the four quadrants Q1 to Q4 marked, vertical lines at t=T/4, T/2 and 3T/4, and horizontal lines at +A, 0 and -A on the displacement axis.
So i ranked it as c < d < b < a
some of them i thought i would not have to add pi ( i made a mistake in op i think it is add pi) and this was incorrect. some of them are not in any quadrant so there is no no need to add. i added pi to a, and that seemed like the only one that needed it
Left: a sine wave displacement curve over one period with points B, D, A and C marked at t=0, T/4, T/2, 3T/4 and T, quadrants Q1 to Q4, and levels +A, 0 and -A. Right: four displacement-time graphs labelled A to D, each with a green dot at t=0.
  • Left: a sine wave displacement curve over one period with points B, D, A and C marked at t=0, T/4, T/2, 3T/4 and T, quadrants Q1 to Q4, and levels +A, 0 and -A. Right: four displacement-time graphs labelled A to D, each with a green dot at t=0.
Your original answers were: A= -π/6 , B=π/2, C= -π/2 and D= 0.
Looking at my diagram, two of these are not correct. What have you now said they are?
Edit: in case you are not familiar with these values;
π = 3.14, π/2 = 1.57, π/6 = 0.53 approx.
b and a were incorrect
i need to just step away from this for a few and go get something to eat
Yeah. I needed to sleep as well.
I disagree with a. (I'll leave the other error for now)
Your calculation sin-1(-.10/.20) = Φ = -0.52 gives one numerically possible result. There is another. You picked the wrong one.
You can see this from the graph -
Two cycles of a sine wave plotted against time in seconds and radians, with time labels t=-2T to t=T and radian values -6.28 to 6.28, quadrants Q1 to Q4 marked, points A, B, C, D on the curve, and a value of -0.52 at t=0.
I've put the origin in the centre and written the phase scale in decimal radians as you used.
You can see that your value of Φ = -0.52 does not correspond with the position of A.
There are two phase angles which give sin(Φ) = -0.5
One is Φ = -0.52 and its aliases 2πN - 0.52 (where N is an integer)
The other is where A is.
Another method you may have used to solve trig equations, implied by your term "quadrant" could be this diagram:
Unit circle with ASTC quadrant labels (Sin, All, Tan, Cos) and a horizontal line at -0.5, with arrows marking angles of -0.52 rad and pi + 0.52 rad from the positive x-axis.
Where you can see that the other solution to Φ = sin-1(-0.5) is Φ = π + 0.52
  • Two cycles of a sine wave plotted against time in seconds and radians, with time labels t=-2T to t=T and radian values -6.28 to 6.28, quadrants Q1 to Q4 marked, points A, B, C, D on the curve, and a value of -0.52 at t=0.
  • Unit circle with ASTC quadrant labels (Sin, All, Tan, Cos) and a horizontal line at -0.5, with arrows marking angles of -0.52 rad and pi + 0.52 rad from the positive x-axis.
