Finding points of intersection
13 replies · 4K views
physicsgal
the parabola equation is:
(x^2/25) - (y^2/9) = 1
the line is y = 4-x
according to my calculations, if i point y - 4-x into the equation, i get
-16x^2 + 200x - 175 = 0. is that right so far?
~Amy
the line is y = 4-x
~Amy
No, it's not correct. =.="
Can you show us how you get there?
I get: -16x2 + 200x - 625 = 0.
Btw, that's definitely not a parabola equation. Instead, it's a hyperbola equation. :smile:
thanks
i meant to say hyperbola :shy:
i have 8 lines of work and my typing numbers is slow.. so here's part of my calculations:
x^2/ 25 - (4-x^2)/ 9 = 1
225(x^2/25) - 225 ((4-x)^2/9) = 225(1)
9x^2 - 25(16 - 4x - 4x + x^2) = 225
9x^2 - 25(16 - 8x + x^2) = 225
9x^2 - 400 + 200x - 25x^2 = 225
i see my mistake now :smile: thanks
and then after i do the quadratic equation, i end up with x = 6.25, so y= -2.25. and that's my only intersection.
~Amy
if you don't mind.. one more hyperbola question:
4x^2 - y^2 + 8x + 4y + 16 = 0
what is this in standard form?
in standard form:
(x+1)^2/4 - (y-2)^2/16 = 1
does that look accurate?
~Amy
in standard form:
~Amy
You can try to expand that and see if you get the same as the initial form :)
thanks. i expanded it and got:
4x^2 - y^2 + 8x + 4y + 4 = 0
so.. either something went wrong when i was expanding, or the standard form i figured out is incorrect?
~Amy
so there was something wrong with my expanding?
~Amy
"if you don't mind.. one more hyperbola question:
what is this in standard form?"
You said, then you gave:
" (x+1)^2/4 - (y-2)^2/16 = 1"
as the normal form of the first equation you gave;
and when this is expand, you get:
4(x^2 + 2x + 1) - (y^2-4y + 4) = 16 ->
4x^2 + 8x + 4 - y^2 + 4y - 4 = 16 ->
4x^2 + 8x - y^2 + 4y - 16 = 0
right?
try:
-[(x+1)^2]/4 + [(y-2)^2]/16 = 1
expand:
-4[x^2 +2x+1] + [y^2 - 4y + 4] = 16 ->
4[x^2 +2x+1] - [y^2 - 4y + 4] +16 = 0 ->
4x^2 + 8x + 4 - y^2 + 4y - 4 + 16 = 0 ->
k thanks :)
but could i write that as:
[(x+1)^2]/4 + [(y-2)^2]/16 = -1
(i don't think its standard form to have a "-" infront of the equation)
and for this one, b^2 = 16 ?
(i have to do other calculations)
~Amy
Well as you said, having a minus in front of the "1" is not standard form. So why do you want to do that?
physicsgal said:
k thanks :)
Nope, you can't. However, you "can" write it as:
[(x+1)^2]/4 - [(y-2)^2]/16 = -1
Yes, you can write it like that, but it's definitely not a standard form.
~Amy
[(y-2)^2]/16 - [(x+1)^2]/4 = 1
Note that it's a North-south opening hyperbola, your b2 = 4. :)
thanks for the help guys :o). I am finished the course (just have to do the exam). :)
~Amy
