Finding potential inside the cavity of a Conductor
The discussion centers on solving a boundary value problem involving a conductor with a spherical cavity and a point charge. The potential inside the cavity is determined using Poisson's Equation and the method of images. The solution is established as V(r) = q(1/r - 1/a)/4πε + V, where r is the distance from the point charge q. This approach simplifies the problem by leveraging the constant boundary condition of the conductor.
  • Understanding of Poisson's Equation
  • Familiarity with the method of images in electrostatics
  • Knowledge of boundary value problems, specifically Dirichlet problems
  • Basic concepts of electric potential and point charges
  • Study the application of Poisson's Equation in electrostatics
  • Explore the method of images in greater detail, particularly in spherical geometries
  • Review boundary value problems and their solutions in electrostatics
  • Investigate electric potential calculations for various charge configurations
Students and professionals in physics or electrical engineering, particularly those focusing on electrostatics and boundary value problems in conductive materials.
xcgirl
A conductor, maintained at a potential V, contains a spherical cavity of radius R.
A point charge q is placed at a distance a ( a < R)from the center of the cavity.
Find the potential of the electric field in the cavity .
I was considering using Poisson's Equation because we recently did that in class. Also, we are learning about the method of images right now. I am really unsure of where to start with this problem. I did another problem successfully that had 2 point charges above an infinite conductor and I simply replicated the opposite of those charges the same distance below the conductor and used the method of images to find the force on one of the charges. But, this problem is asking for potential, not force and the sphere cavity thing makes it weird for me. I don't even know where to start. Any hints would be helpful :\
This is just a simple boundary value problem (of the Dirichlet type) where one seeks a function obeying Poisson's equation in the spherical cavity and taking the constant value V on its boundary. If you can find such a function, you're done. This problem is designed to make it especially easy and you can check that V(r) = q(1/r-1/a)/4πε+V is the solution, where r is the distance from the point charge q.
  • · Replies 22 ·
  • · Replies 17 ·
