Efficiently Solving a Cubic Equation Using Synthetic Division
  • Thread starter Thread starter FaraDazed
    Cubic
The discussion focuses on solving the cubic equation x^3+6x^2-8x+1 using synthetic division. The initial solution identifies +1 as a root, allowing the equation to be factored as (x-1)(x^2+7x-1). Coefficients are equated to find A, B, and C, confirming the factorization is correct. A participant suggests that synthetic division would be a more efficient method than the approach taken. Ultimately, the real solutions are x=1, x=(-7+√53)/2, and x=(-7-√53)/2.
FaraDazed
Find the real solutions of x^3+6x^2-8x+1
quadratic
First I tried simple numbers starting with 1 and found that +1 was a solution and therefore I could write
<br /> x^3+6x^2-8x+1=(x-1)(Ax^2+Bx+C) \\<br /> x^3+6x^2-8x+1=Ax^3+Bx^2+Cx-Ax^2-Bx-C \\<br />
And then equated the coeffeciants
For x^3, 1=A
For x^2, 6=B-A
For x^1, -8=C-B
For x^0, 1=-C
With knowing that A=1 and C= -1 , B can be found to be 7 .
And therefore I can write x^3+6x^2-8x+1=(x-1)(x^2+7x-1)
If I then use the quadratic formula on the quadratic factor I end up with
\frac{-7\pm\sqrt{53}}{2}
And as 53 is prime that is as far as it can go without losing accuracy.
I don't know if this is all I have to do, if I have done what I have done correctly or what. I am a bit confused. Any help/advice appreciated.
That looks entirely correct, and is all you have to do. You can include a line at the end that says
Therefore, the solutions are x=1,\ x=\frac{-7+\sqrt{53}}{2} and x=\frac{-7-\sqrt{53}}{2}
Likes 1 person
quadratic
For x^3, 1=A
For x^2, 6=B-A
For x^1, -8=C-B
For x^0, 1=-C
I'm curious why you didn't just divide the cubic by ##x-1## using either long division or, preferably, synthetic division to get the quadratic factor. Much less work...
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 39 ·
