Finding sphere mass with varying density c=1+rz
  • Thread starter Thread starter matt222
    Mass Sphere
19 replies · 6K views
matt222
problem is attached
I confused with the question, to find the mass we have to find the volume of the sphere and then multiply it by the given density, what I did is we have the radius of the sphere is a and the sphere volume 4/3*pi*a^3, density as it specified c=1+rz,at this point I noticed that i am doing wrong thing, can you help me please to find it out
Recall that the mass of a continuous object is given as int(dm) and dm=p*dV, in this case dm=c*dV . The nice thing about your problem is that it's a regular sphere with radius, a, centered at the origin. Start thinking about what your differential volume element for your sphere is...
If the center of the sphere is located on the origin, take the quarter that lies between the positive X and Y axes. Find the equation of a differential volume (f(x)*f(y)*dz), multiply it by your density function and integrate from -z to z. You should then get an equation for the mass of that quarter of the sphere. Multiply by 4 and you get your answer.
it should be dv=a^2sin(theata)dad(theata)d(phi), is it right
or consider volume of top half (as z is positive, the total mass will be 2 times due to symmetry) in spherical coords
[tex]m = \int \int \int \rho(r, \theta, \phi) r sin(\theta) dr. d \theta. d \phi[/tex]
i'll let you complete the limits and integrand, and the integration should straight forward
i understad from you clearly, so when we take the half top on poistive z, the limit should goes from 0 to a for dr term, 0 to pi for theta and phi, is it true
one more thing in the density term in our question we have two terms one constant 1 and the other one is r*z, i confused now with rdr we have and z as well, constant 1 , so in this case we take two integration part or by letting the density c all the way and integrating without opening c
Yes.
(Note: I assume you are using "engineering" notation which swaps [itex]\theta[/itex] and [itex]\phi[/itex] from "mathematics" notation- [itex]\theta[/itex] is the "co-latitude" and [itex]\phi[/itex] is the "longitude".)
what about the density term i have two terms constant 1 and r*z, how we are going to relate this because we have now radius a , r any distance from the sphere z no idea about it,
is the final answer going to be 2*a^2*pi*c
I'm looking at the "c" in ur answer:bugeye:
c is the density if you read the question attached
but i suppose c isn't constant
i really confused with the term of density c=1+r*z
No, the volume element depends on the radial coordinate r, not the radius of the sphere a. It should be
[tex]dv = r^2 \sin\theta \,dr\,d\theta\,d\phi[/tex]
You have the correct limits for r, but not for the other variables.
You just plug the expression for the density in. First, take the volume element dv and multiply by the density c to get dm:
[tex]dm = c\,dv = (1+r|z|)r^2\sin\theta \,dr\,d\theta\,d\phi[/tex]
And then integrate:
[tex]M = \int dm = \int\int\int_0^a (1+r|z|)r^2\sin\theta \,dr\,d\theta\,d\phi[/tex]
I'll leave it to you to determine the correct limits for the angular variables and to work out the integral itself. You'll have to express z in terms of the integration variables.
the limit for theta is from 0 to pi, for phi from 0 to 2*pi, z=rcos(theta), is it true the limits and the value for z
Yes, that's correct. To actually evaluate the integral, you may want to use lanedance's suggestion to integrate over just the top half of the sphere and then double the result.
the final answer will be 4*pi*a^3/3, is it right
i have problem with the limit of theta and phi, so from landance's said, theta if its top it will goes from 0 to pi/2, and for phi from 0 to pi, then integrating whole and multiply by 2, but can you check my intgeral limits are true or wrong
No, the correct answer is
[tex]M = \frac{4}{3}\pi a^3 + \frac{2}{5}\pi a^5[/tex]
Your limits for θ are correct, but your limits for ϕ are not. ϕ should still go from 0 to 2π.
