Finding start of ferrite transformer
  • Thread starter Thread starter microman
    Transformer
This discussion focuses on determining the start of each winding in a ferrite core transformer, specifically for a flyback converter designed to convert 9V to 90V at 1mA using a square wave at 60kHz. Participants suggest using a sine wave generator to measure output on the second winding for polarity and turns ratio, or alternatively, manually pulsing a DC current to observe the response on an oscilloscope. The conversation also touches on the proper driving method for flyback transformers, emphasizing the importance of avoiding core saturation during operation.
  • Understanding of flyback transformer operation
  • Familiarity with oscilloscopes and waveform analysis
  • Knowledge of DC-DC converter design principles
  • Experience with basic circuit components like diodes and capacitors
  • Learn about flyback converter design and operation
  • Research the effects of different waveforms (sine vs. square) on transformer behavior
  • Study the principles of transformer polarity and turns ratio measurement
  • Explore advanced techniques for preventing core saturation in transformers
Electrical engineers, hobbyists working with power electronics, and anyone involved in designing or troubleshooting flyback converters will benefit from this discussion.
microman
Hello ,
I have a ferrite core transformer with two separate windings. I was hoping if someone can tell me if I can locate the start of each winding relative to each other.
I have a scope, and am comfortable with micro based circuits.
Cheers
Thomas
It sounds like you want to determine the polarity of the two windings with respect to each other? If so, put a sine wave of the appropriate frequency (do you know what frequencies this transformer is designed for?) into the 1st winding, and measure the output on the 2nd winding. That will give you the polarity and turns ratio.
Welcome to the PF, BTW!
There is even a cheaper method if you don't have a sine wave generator. Just manually pulse a DC current in one coil and observe on the oscilloscope whether the spike in the other coil goes positive or negative.
Hi Berkeman , what,
Thanks for the response to my post and the welcome to PF. I am attaching a pdf ,would the output waveform be as it is there ? Would there be any difference between a Sine and a square wave for this check ?
This flyback txfer is for a dc-dc low power converter ,square wave at 60kHz,to convert from 9V to 90V at 1mA.
Thanks again.
oops no attachment,so trying again
That's not how you would generally drive a flyback transformer. The secondary output winding (with more turns for the step-up function) would be grounded on the dot polarity end, and the non-dot end of the secondary would have a rectifying diode connected with an output smoothing capacitor.
You drive the flyback converter by putting a positive supply and capacitor on the dot end of the primary, and using a low-side transistor switch to pull down the bottom of the primary for the energy-storage phase. You would choose the drive frequency (or on-time pulse width) at the primary to stay short of saturating the core.
I guess the way you've shown a "test drive" circuit to verify the polarity dots is probably okay, it just gives me a bit of vertigo when used in the context of a flyback converter circuit.
EDIT -- Ack, I was brain dead. I've corrected a polarity error in the secondary part of this post, and sent the OP a PM to be sure they know about my error. Jeeze, sorry for any confusion. I realized my error sitting in a waiting room this afternoon, with no Internet access. Here's a summary page from wikipedia.org about about flybacks:
http://en.wikipedia.org/wiki/Flyback_converter
Hello Berkeman,
Thanks for your post.Yes I am aware of the flyback configuration.This was purely for verifying the start end of each coil.So i guess the waveform should be ok to verify the start ends of the txfer.
In case anyone is more interested here is a link to a nice site on power converter topologies and a design methodology.
http://schmidt-walter.fbe.fh-darmstadt.de/smps_e/trafo_hilfe_e.html
