Finding tangent lines for 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6
  • Thread starter Thread starter ttpp1124
    Lines Tangent
The discussion focuses on finding tangent lines for the function 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6 from the point (-2, 8). It is established that the point does not lie on the curve, necessitating the calculation of slopes of lines that touch the curve tangentially. Participants suggest using Wolfram to sketch the curve or manually identifying extrema and inflection points. The process involves setting equations based on the coordinates of the tangent point and the slope condition, leading to a system of equations that can be solved for the tangent points.
  • Understanding of calculus concepts, specifically derivatives and tangent lines
  • Familiarity with polynomial functions and their properties
  • Ability to solve systems of equations
  • Experience with graphing tools such as Wolfram Alpha
  • Learn how to calculate derivatives of polynomial functions
  • Explore the use of Wolfram Alpha for graphing functions and analyzing curves
  • Study methods for solving systems of equations in two variables
  • Investigate the concepts of extrema and inflection points in calculus
Students and educators in mathematics, particularly those studying calculus, as well as anyone involved in solving problems related to tangent lines and curve analysis.
ttpp1124
Consider the curve defined by 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6. What is the slope of tangent(s) line to the graph of 𝑓(𝑥) from the point 𝑃 (−2, 8)?
n/a
not quite sure if this is right.. can someone confirm?
It is not correct. The point (-2,8) does not lie on the curve. You need to find the slopes of the line(s) that go through that point and touch the curve somewhere at a tangent.
I suggest you start by sketching the curve, either by identifying any extrema, inflection point and limits as x goes to +/- infinity and sketching it yourself, or using Wolfram to sketch it for you. With a sketch you should be able to tell how many lines that touch the curve at a tangent there will be.
Then you need to write some equations. Set (a,b) as the (x,y) coordinates of a tangent point. You will get equations from the fact that (a,b) lies on the curve, and that the line through (-2,8) and (a,b) has the same slope as the curve at (a,b). That's two equations and two unknowns, which you can solve to find a and b. Then calculate the slope at that point.
Edit: On second thoughts, you don't need to sketch it. Just make the equations and solve. There will be one or two solutions according to whether there are one or two tangents from the point to the curve.
Is this better?
@ttpp1124, both images in this thread are posted sideways. Many helpers won't bother looking at them if they have to crane their heads sideways to read what you've written.
sorry, here's the upright version!
Your answers for the two slopes look fine to me.
