Finding tangent lines for 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6
In summary, the point (-2,8) does not lie on the curve. You need to find the slopes of the line(s) that go through that point and touch the curve somewhere at a tangent.
ttpp1124
110
Consider the curve defined by 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6. What is the slope of tangent(s) line to the graph of 𝑓(𝑥) from the point 𝑃 (−2, 8)?
n/a
not quite sure if this is right.. can someone confirm?
It is not correct. The point (-2,8) does not lie on the curve. You need to find the slopes of the line(s) that go through that point and touch the curve somewhere at a tangent.
I suggest you start by sketching the curve, either by identifying any extrema, inflection point and limits as x goes to +/- infinity and sketching it yourself, or using Wolfram to sketch it for you. With a sketch you should be able to tell how many lines that touch the curve at a tangent there will be.
Then you need to write some equations. Set (a,b) as the (x,y) coordinates of a tangent point. You will get equations from the fact that (a,b) lies on the curve, and that the line through (-2,8) and (a,b) has the same slope as the curve at (a,b). That's two equations and two unknowns, which you can solve to find a and b. Then calculate the slope at that point.
Edit: On second thoughts, you don't need to sketch it. Just make the equations and solve. There will be one or two solutions according to whether there are one or two tangents from the point to the curve.
Is this better?
@ttpp1124, both images in this thread are posted sideways. Many helpers won't bother looking at them if they have to crane their heads sideways to read what you've written.
sorry, here's the upright version!
Your answers for the two slopes look fine to me.
1. What is a tangent line?
A tangent line is a straight line that touches a curve at only one point. It represents the slope of the curve at that point.
2. How do you find the slope of a tangent line?
The slope of a tangent line can be found by taking the derivative of the function at the point of interest. In this case, the derivative of 𝑓(𝑥) = 𝑥^3 − 𝑥 + 6 is 𝑓'(𝑥) = 3𝑥^2 - 1. Plug in the x-coordinate of the point of interest into the derivative to find the slope.
3. What is the process for finding tangent lines?
To find the tangent line of a function at a specific point, you must first find the derivative of the function. Then, plug in the x-coordinate of the point into the derivative to find the slope. Finally, use the slope and the point to write the equation of the tangent line in point-slope form.
4. How many tangent lines can a function have?
A function can have multiple tangent lines at different points. However, at any given point, a function can only have one tangent line.
5. Are tangent lines always straight?
Yes, tangent lines are always straight. This is because they represent the slope of a curve at a single point, and the slope of a straight line is constant.
