Finding the angle after an elastic collision
6 replies · 2K views · last reply
ILoveParticlePhysics
I think it has to do with conversation of momentum and projectile motion.
ILoveParticlePhysics said:
Summary:: Let's say you have a 1kg ball going 5km per hour going straight into the middle of 2 5kg balls, what will be the angle and the speed of every ball after the collision?
Note: I just want the formula not the answer for the actual summary :).
Is this your homework?
How is "the formula" different from "the answer"?
No. The example was an example not homework.
There isn't, old me said that so people wouldn't think that it is homework which it isn't.
Usually, the answer to problems of this sort is a formula when numbers are not given and a number if numbers are given. Here you are asking for an answer in the form of a formula. Having said all this, the only answer to your question is "It depends" because you have not given enough information. Ideally, there will be a 3-way split of the initial energy and momentum, the angles of the 5 kg balls relative to the initial direction of the 1 kg ball will be equal in magnitude, but in opposite quadrants and the speeds of the 5 kg balls will be equal. All that is deduced theoretically from symmetry. Practically, it will be a different story. In real life, you cannot expect to have a three-way collision so that all three balls are in contact for the same time interval. One collision will be completed before that other and that will skew the result. Even in ideal conditions, the statement of the problem should provide more information. The scattering angle will depend on the radii of the balls because the velocity of a target ball at rest will be in the direction of the line joining the centers of the projectile and target ball.
Where did you find the example? The reason I ask is because the example is not well stated.
