Finding the angle between two magnitudes.
  • Thread starter Thread starter Daweih
    Angle Magnitudes
The discussion centers on calculating the angle between two displacement vectors of magnitudes 3.3 m and 4.3 m, resulting in various resultant magnitudes (5.1 m, 2.8 m, and 4.7 m). The law of cosines, expressed as c² = a² + b² - 2abcosγ, is correctly identified as the method for solving this problem. However, participants clarify that the angle calculated using this law represents the angle when the vectors are placed head to tail, not the angle between their directions. The correct approach involves recognizing that the angle between the vectors' directions is supplementary to the angle found using the law of cosines.
  • Understanding of vector addition and displacement
  • Familiarity with the law of cosines
  • Basic trigonometry, including angle calculations
  • Ability to visualize vector placement (head to tail)
  • Study the law of cosines in-depth, particularly its applications in vector problems
  • Learn about vector direction angles and their supplementary relationships
  • Explore graphical methods for vector addition and resultant calculation
  • Practice problems involving multiple vectors and resultant magnitudes
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators seeking to clarify vector addition concepts.
Daweih
Consider two displacements, one of magnitude 3.3 m and another of magnitude 4.3 m. What angle between the directions of this two displacements give a resultant displacement of magnitude (a) 5.1 m, (b) 2.8 m, and (c) 4.7 m.
I've been using the law of cosine to work out this problem, but my answers have all come out to be wrong. Am I incorrect in using it to solve this problem or am I just doing my math wrong?
c^2 = a^2 + b^2 - 2abcosγ
My answers are as follows: a) 83° b) 41° c)75°
I would really appreciate the help. =(
Without working the problem myself: (Don't you love it when someone qualifies their answer this way?)
I suspect that your answers are correct for the angle the vectors make if you lay them head to tail, as you would in constructing a triangle composed of the two vectors and their resultant.
However, that is not the same as the angle between the vectors directions. The angle between the vectors directions is the supplement of the angle between the vectors when placed head to tail.
Ah, I understand now. Thank you very much. That clears up everything for me. =)
You are correct with Law of Cosines. I got 83.18 for a, so your data is correct. How are you drawing a,b and c? Hopefully you can see that (for a) C=5.1m
I can't just give you the answer, but try a variation of law of cosines:
C=cos-1(a2+b2-c2)/(2ab)
Try that.
  • · Replies 26 ·
