Finding the base of numbers from a given equation
  • Thread starter Thread starter kliker
    Base Numbers
The discussion revolves around solving the equation x^2 - 11x + 22 = 0 and finding the base of the numbers represented by its roots, which are x = 3 and x = 6. Participants explore various methods to derive the base, with one contributor initially using incorrect calculations that led to an erroneous conclusion of b = 2 and b = -2/3. Another participant suggests a more straightforward approach, indicating that if the base is B, then the relationships b = -B - 1 and c = 2B + 2 can be applied. Ultimately, it is confirmed that the correct base is 8, and the simpler method is recommended for future problems.
kliker
x^2 - 11x + 22 = 0
the roots are x= 3 and x = 6
what's the base of the numbers?
ok what I've done is I found the roots in decimal system which are
x1 = (11+sqrt(33))/2 and x2 = (11-sqrt(33)/2
then I said x1 = 3 and x2 = 6 so we have
3 = (11+sqrt(33)/2 <=> 6 = 11+sqrt(33) <=> -5 = sqrt(33) <=> 25 = 33 <=> 2b + 5 = 3b + 3 <=> b = 2
im doing the same for the second root
6 = (11-sqrt(33)/2 <=> 12 = 11 -sqrt(33) <=> 1 = -sqrt(33) <=> 1 = 33 <=> 1 = 3b + 3<=>
3b = -2 <=> b = -2/3
i know that my method is wrong, the correct answer is 8 but that's what I thought would solve this problem, it's the first time that I see this kind of problem, so if anyone could guide me I would apreciate it
Do you know the formulas that express the coefficients (-11 and 22) of the polynomial in terms of its roots (3 and 6)?
Petek
Petek
i'm not sure, do you mean something like this:
22 = 6 <=> 2b + 2 = 6 <=> b=2
sorry I am not that good in english :(
Suppose that the polynomial x^2 + ax + b has roots r and s. Then we can write x^2 + ax +b = (x - r)(x - s). Expand the expression on the right side of the equation. You then should be able to get formulas for a and b in terms of r and s. Do you see how this helps to solve your original question?
Petek
kliker said:
x^2 - 11x + 22 = 0
You pick the hard way to do it but it can work if you do it right
x^2 + bx + c if The base is B then B+1 = -b and 2B+2 = c
so 3 = (-b -sqrt(b^2-4ac))/2 = (B+1 - sqrt(B^2-6B -7))/2
This is very difficult to solve but if you set B = 8 you can see it works!
Try Petek's suggestion. It is a lot easier Just remember b = -B-1 and c = 2B + 2
thanks Petek I totally forgot about this
ramsey2879, thank you too
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
