Finding the Bases for kernel and range of linear transformation.
The discussion revolves around finding the bases for the kernel and range of a linear transformation T: R4 → R4, which maps specific vectors to given outputs. The original poster seeks to understand how to derive these bases and the associated transformation matrix.
  • Participants discuss the method for finding the kernel, noting that the transformation takes two vectors to one, leading to a basis for the kernel. There is uncertainty about how to find the basis for the range and the transformation matrix. Some participants clarify the properties of linear transformations and question the assumptions made in the original poster's reasoning.
There is active exploration of the kernel's basis, with some participants confirming the vectors that map to zero under the transformation. However, the basis for the range remains unclear, and participants are seeking guidance on how to proceed with that aspect of the problem.
Participants note the complexity of the transformation due to multiple vectors mapping to the same output, which complicates the identification of the transformation matrix. There is also mention of the Gram-Schmidt process for finding an orthonormal basis for the kernel.
avister51291
How do I find the bases for both the kernel and range of this linear transformation?
Let T: R4 ----> R4 be the linear transformation that takes [1101] and [1011] to [2304] and takes [1110] and [0111] to [3120]
a. Find the bases for both the kernel and the range of this linear transformation.
b. Give and orthonormal basis for the kernel of this transformation
c. Indicate the matrix that would represent T under the standard basis for R4
Gram-Schmidt
u1 = v1
u2 = v2 - (<v,u>/<u,u>)u
For part a:
I can find the basis for the kernel but I do not know how to find it for the range.
Basis for Kernel:
Since the transformation takes two vectors to one, I used this property to find out the
basis for the kernel, which is T(u - v) = [1101 -1011] = [0,1,-1,0]
I did the same for the other two vectors which resulted in [1,0,0,-1].
Basis for the Range: ?
For part b:
I took the two basis vectors and used the Gran-Schmidt to find the orthonormal basis for the kernel which is {[tex]\sqrt{}2[/tex]/2 (1,0,0,-1), [tex]\sqrt{}2[/tex]/2(0,1,-1,0)}
for part c: I do not know how to do it. I know how to find a transformation matrix given two transformations that go to different vectors; however, that is not the case here as two vectors transform to the same vector. This happens for two different sets.
Gram-Schmidt
u1 = v1
For part a:
Basis for Kernel:
You're being very sloppy here. For a linear transformation T, it must be true that T(u - v) = T(u) - T(v).
So T(u - v) = T([1101] -[1011]) = T[0,1,-1,0]
and T(u) - T(v) = [2 3 0 4] - [2 3 0 4] = [0 0 0 0].
So T[0,1,-1,0] = [0 0 0 0].
Is this what you meant to say?
Do you mean to say that T[1,0,0,-1] = [0 0 0 0]?
From this it appears that the ker(T) is at least dimension 2 and maybe more.
For part b:
Yes, for part A I meant that in order to find the basis for the kernel I would need to do
T(u-v) = T(U) - T(V). The vectors that would go to [0 0 0 0] under the transformation are
[0,1,-1,0] and [1,0,0,-1].
So the basis for the kernel of this transformation is B= {[0,1,-1,0], [1,0,0,-1]}
How would I go about finding the basis for the range and transformation matrix by looking at what I was given?
Let's give these vectors some names:
u1 = [1101]
u2 = [1011]
u3 = [1110]
u4 = [0111]
From your previous work, you know that T(u1 - u2) = 0 and that T(u3 - u4) = 0.
IOW, you know that T([01-10]) = 0 and T([100-1]) = 0.
What about T(u1 + u2)? T(u3 + u4)?
9K
