Finding the coefficient of restitution
The discussion revolves around finding the coefficient of restitution for a body rebounding off a smooth circular wall. The coefficient is defined as the ratio of relative speeds before and after the collision, leading to the equation e = (v' sin α) / (v cos α). The conversation highlights the significance of the wall being smooth, indicating that the tangential component of momentum is conserved during the collision. Participants clarify that momentum conservation applies to the tangential direction, which ultimately leads to the correct relationship v sin α = v' cos α. The final conclusion is that the coefficient of restitution is e = tan² α.
Saitama
A body is fired from point P and strikes at Q inside a smooth circular wall as shown in figure. It rebounds to point S (diametrically opposite to P). The coefficient of restitution will be:
(Ans: ##\tan^2\alpha##)
Let ##v## (along PQ) be the velocity before collision and ##v'## (along QS) be the velocity after collision.
The coefficient of restitution (e) is defined as:
$$e=\frac{\text{Relative speed after collision}}{\text{Relative speed before collision}}$$
The numerator is ##v'\sin\alpha## and denominator is ##v\cos\alpha##. (The relative speed is measured along normal at the point of collision)
Hence,
$$e=\frac{v'\sin\alpha}{v\cos\alpha}=\frac{v'}{v}\tan\alpha$$
From conservation of linear momentum along PS:
$$mv\cos\alpha=mv'\sin\alpha \Rightarrow \frac{v'}{v}=\cot\alpha$$
Hence,
$$e=1$$
:confused:
Any help is appreciated. Thanks!
Why would this be true? Notice that the problem says that the surface of the wall is smooth.
Yes but I don't see how it has got anything to do with conservation of momentum. :confused:
"Smooth" means that the wall will not exert any tangential component of force on the body.
Why are we talking about the tangential force now? Had it been present, does it mean that momentum would be conserved? :confused:
If there is no force on a body in a certain direction, what does that mean about the component of momentum of the body in that direction?
The momentum is conserved in that direction.
Do you mean I should conserve momentum in radial direction?
Yes. So, smooth means that the tangential component of momentum will be conserved. That is, the component of momentum parallel to the wall at the point of collision will be conserved.
Note that PS is not the tangential direction.
No, the tangential component (parallel to the wall) is conserved.
Likes 1 person
Thanks TSny! :smile:
This time I get, ##v\sin\alpha=v'\cos\alpha## which gives the right answer.
This time I get, ##v\sin\alpha=v'\cos\alpha## which gives the right answer.[/QUOTE
How do you get this relation? Can you please explain further?
