Finding the density inside a tank as air escapes
3 replies · 2K views
Lee Cousins
A tank of constant volume V contains air at an initial density pi. Air is discharged isothermally from the tank at a constant volumetric rate of Q (with SI units of m^3/s). Assuming that the discharged air has the same density as that of the air in the tank, find an expression for the density in the tank, p(t).
There's also a diagram of the circular control volume V with one outlet which air escapes at Q.
Mass conservation equation is integral of (p dv) + integral of (pv*dA) = 0
I got the equation down to dp/dt = (-pi*Q)/V but that's not right so I'm not sure what to do from here.
There must be something wrong with this equation. The two summands have different dimensions.
Plus I suggest to use the common symbols. The density's symbol is ##\rho## (rho), whereas ##p## stands for the pressure. Also the symbol ##v## is confusing (I suppose it should be the velocity). However, try to use the common symbols and also explain them in the text, if they could be ambiguously (##v## also could be the specific volume, then ##\int p dv## would be something completely different).
Okay, I'm new to this but I meant to say ##\int ##\rho## dv## + ##\int ##\rho## V dA##
I can't quite get the syntax down. But its the integral with respect to the control volume of the density * the dv (volume) + the integral with respect to the surface area of the density * the volume * dA (Area)
Regarding the syntax: You only have to write two hashtags before and after the entire expression, not for every symbol.
However, the first summand in your equation ##\int \rho dv## has the unit ##kg/m^3 \cdot m^3 = kg##. The second summand in your equation ##\int \rho v dA## has the unit ##kg/m^3 \cdot m^3 \cdot m^2 = kg\cdot m^2##. So the units are not consistent.
You start with an initial mass of air ##m_0## in the tank. Then there is a mass flow ##\dot{m}## exiting the tank with time. Now the mass conservation says that the mass in the tank must be the initial mass minus the air flow over the time.
##m_0-\dot{m}t=m\left(t\right)##
Based on this equation, try to find the answer by substituting, re-arranging etc.
