Finding the density of a 3.85 kg trophy
  • Thread starter Thread starter Luke White
    Mass Volume
14 replies · 2K views
Luke White
Find the density
Luke White said:
mass per unit volume as i know .
Right, so if you are given a mass of 3.85 kg and a volume of 480 cm3, what would be the mass per unit volume?
Luke White said:
how can you work it out?
Were you taught the concept of density and the formula associated with it?
If meter per second means 1 m divided by 1 s, what what mass per unit volume give?
Luke White said:
its p=m/v how can I find the density?
what do m and v represent in your equation?
Luke White said:
mass and volume...
Good. And you are told mass = 3.85 kg and volume = 480 cm3, so if you put those values into your formula, what do you get?
I have to divide them? Then it says that gold has a density of 19,000kg/m3 . Is the throphy made out of real gold
Yes you have to divide them. If you are given those values and your density doesn't match up to 19,000 kg/m3, then it isn't made out of real gold.
so 3.85 divide 480 = 8.02083333 <--- density... so not real gold
Yes, but don't forget your units. You divided kg by cm3, so your units are kg/cm3
