Finding the diameter of a coil.
  • Thread starter Thread starter cds5615
    Coil Diameter
The problem involves determining the diameter of a coil made from a 1.2-meter-long copper wire, intended to generate a 0.60 mT magnetic field at its center with a current of 1.5 A. The challenge lies in using the entire wire to form an N-turn current loop.
  • Participants discuss various formulas related to magnetic fields and current loops, questioning the application and derivation of these equations. There is uncertainty about how to relate the number of turns to the diameter of the coil.
The discussion is ongoing, with participants exploring different equations and methods to find the diameter. Some guidance has been offered regarding the use of Ampere's law, but there remains a lack of consensus on how to directly apply it to find the diameter.
Participants are navigating through assumptions about the uniformity of the coil and the relationship between the number of turns and the dimensions of the coil. There is mention of constraints related to using the entire length of the wire and the need for clarity on the number of turns.
cds5615
You have a 1.2-m-long copper wire. You want to make an N-turn current loop that generates a 0.60 mT magnetic field at the center when the current is 1.5 A. You must use the entire wire.
What will be the diameter of your coil?
I tried applying this formula d = sqrt ( (mu*L*I/pi*B)) and keep getting a really small number =0.000021 m
What am I missing here??
What was the original formula? Name of it?
I actually just got it from a classmate, him and his friend were both able to get to the answer from that equation.
I tried using B= mu*(N/L)*I but you don't end up with a numerical value when solving for d. There must be a way to find the answer with another method...
Ahhh I see, well I'll s how you how to do it. Use Ampere's law. [tex]BL = IN\mu_0[/tex]
It will yield the correct answer, and I can see whoever wrote the question planned it very well.
But I am solving for diameter. How can I apply that equation?
Well.. You know everything except for N (number of turns).
Once you've found how many turns you have divide the length of the coil by N. That will clearly give you the circumference of each turn (provided they are uniform).
