Finding the displacement thru position vectors
To find the displacement vector between points A(2,3,4) and B(-4,-5,3), the equation vector AB = (x2-x1)i + (y2-y1)j + (z2-z1)k is used. The displacement vector must have a magnitude of 10m and point in the same direction as vector AB, which is calculated as (-6i -8j -k)/sqrt(101). This indicates that while the displacement vector shares the direction of vector AB, it is not identical to it; instead, it is a scaled version. The average velocity of the particle can be determined by dividing the displacement vector by the time of motion, which is 2.5 seconds. Understanding the relationship between the magnitude and direction is crucial for solving the problem accurately.
pratjoehahn
A particle is displaced by 10m along a direction joining 2 points having coordinates A(2,3,4) and B(-4,-5,3).Find the displacement vector if the time of the motion is 2.5 seconds.Find avg. velocity of this particle.
vector AB = (x2-x1)i + (y2-y1)j +(z2-z1)k
using the above equation I got the position vectors but I don't know how to do anything after that...I can maybe but displacement is already given(10m) so why does it tell to find the displacement again.
Behind the book I checked the answers and got this 10[(-6i -8j -k)/sqrt(101)].
It wants the displacement vector along the direction of the vector from A to B.
This vector will have a magnitude of 10 m, and will be in the direction of the vector from A to B.
but the answer still bugs me ... I know 10 is the magnitude but what is (-6i -8j -k)/sqrt(101) ?
The displacement vector of 10m has the same direction as the vector (B-A) but it is not identical to (B-A). Hint: think unit vector multiplied by a magnitude.
  • · Replies 30 ·
